RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   help with o ring size on df exaust (https://www.rcuniverse.com/forum/rc-jets-120/5558667-help-o-ring-size-df-exaust.html)
Gregor32 03-14-2007 01:33 AM
1 Attachment(s)
hi, just wondering if any one knows the size of the o ring bvm uses on his pipe hanger?
thanks greg
Thud_Driver 03-14-2007 10:44 AM
RE: help with o ring size on df exaust
OD of 1.5" will work by 3/32" thickness.
Try this part number at mcmaster.com: 9452K93
Shaun Evans 03-14-2007 11:31 AM
Hi,
I used a zip-tie back there. My O-rings kept breaking and leaving my pipe without support back there. I don't know about the BVM pipe coupling, but the JMP one had enough rubber up front to handle all of the vibration-related concerns.
joeflyer 03-14-2007 12:28 PM
It's a number 125 o-ring (3/32"w X 1 5/16"id X 1 1/2"od). Make sure you get a Viton o-ring. The cheaper nitrile (or buna) rubber ones the hardware stores sell can't take the high temperature and will break after a few runs. I usually put on two viton ones for extra insurance.
I have some extras left over that I'll never use. I don't know what postage to Australia would cost but if you reimburse me I can mail you a couple.
Joe
Gregor32 03-14-2007 04:01 PM
Thanks Thud driver, Shaun and Joe that was the info i needed. Joe- thanks for the offer but the orings are readily avaliable here, i just needed to know the part#. Shaun i thought the exaust would be too hot for a cable tie!
Thank you all, Greg
KC36330 03-14-2007 04:45 PM
1 Attachment(s)
ORIGINAL: Gregor32
the black ones are for high temp and also have UV protection to prevent deterioration in sunlight. i use them on all my pipe retainers, included a pic of the DD as it's easier to see it :)
kc
