RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   NEED HELP FINDING THIS MATERIAL (https://www.rcuniverse.com/forum/rc-jets-120/5738024-need-help-finding-material.html)
COPYCAT 04-18-2007 10:54 PM
1 Attachment(s)
I AM BUILDING COMPOSITE WING FOR A SCRATCH BUILT JET(SKIN HINGING) NEED HELP FINDING THIS MATERIAL ,I
GOT THIS PIECE FROM A COMP ARF WING THAT WAS CRASHED
Airforce7 04-19-2007 10:43 AM
RE: NEED HELP FINDING THIS MATERIAL
Take a look at Tap Plastics website under Fiberglass. You'll find a variety of fabrics that I think will meet your needs. You can buy it online.
http://www.tapplastics.com/shop/category.php?bid=6&
Ken
LN-JET 04-19-2007 01:32 PM
The material with the red stripe is a nylon material called "Peel ply".
Ask for it at any supplier of fiberglass and composites.
Lars
Woketman 04-19-2007 04:04 PM
That sure does not look like peel ply to me. It looks like regular fiberglass cloth with some red threads in it (don't know why). It could be Kevlar if the color is off (Kevlar is normally quite yellow).
Jack28 04-19-2007 06:21 PM
Normally Plain weave Kevlar is used in skin hinges, Check with Aerospace composites, or Composite Structures Technology (CST). Good Luck.
Ron Stahl 04-19-2007 08:19 PM
That is not peel ply. It appears to be fiberglass with witness strands so you can see the positon of the weave patterns in between multipe layers.
COPYCAT 04-19-2007 08:55 PM
THANKS GUYS FOR YOUR INPUT THE MATERIAL IS PEEL PLY AND I FOUND IT ON LINE IT IS THE SAME MATERIAL USED FOR SKIN HINGING IT IS 2.45 OZ PEEL PLY WITH A RED TRACER IT IS .08 MM THICKER THAN THE ONE WE USE FOR VACUM BAGGING.
Gordon Mc 04-19-2007 09:00 PM
Sorry of this seems a bit off of the main question in this thread .. but I can't stop wondering why a piece of unwetted glass cloth, or peel ply, or whatever .... was inside a comp-arf (or any other) wing.
COPYCAT 04-19-2007 09:08 PM
THE MATERIAL I POSTED WAS PEELED OF THE HINGE POINT OF A COMP ARF WING AND THE SAME MATERIAL WAS ALSO IN THE RUDDER OF ANOTHER MANUFACTURER KIT.
