RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Whats wrong....? (https://www.rcuniverse.com/forum/rc-jets-120/5911092-whats-wrong.html)
TREADSTONE 05-28-2007 06:25 AM
Whats wrong....?
1 Attachment(s)
In this little neat Gear/Brakes fill & air tank contents mount, is there something else i need to buy..?....The air seems to return to atmosphere as soon as i disconnect the filling adaptor ( the Brass thingy.)
Brg
Dave
Spartan Missile 05-28-2007 06:49 AM
RE: Whats wrong....?
Methinks the brass coloured bit should be permanently attached to your air-pump
When unscrewed, the blue bit will seal.
siclick33 05-28-2007 06:52 AM
You also need a model plugged into the other end:D
Does the pressure hold with the pump still attached?
mick15 05-28-2007 07:08 AM
Very good siclick, you’ve brought humour to a whole new level!
m
TREADSTONE 05-28-2007 07:37 AM
ORIGINAL: Spartan Missile
...Thank you Spart...:)..master of the obvious..
TREADSTONE 05-28-2007 07:44 AM
Yeah...Ive disconected all the pipework.
.. the pressure still bleeds away slightly with both the electric ( ALDI ;) ) and manual (robart ) air pump still attatched..Summats amiss for sure...[>:]
Spartan Missile 05-28-2007 07:54 AM
ORIGINAL: TREADSTONE
I don't think that matters Dave.
As long as the air system in your jet does not leak, that's what's critical.
I've had my ALDI pump to bits, it's not high tech stuff, it might be leaking there.
If you need nose-weight, fly with your ALDI pump attached......................................:D
siclick33 05-28-2007 08:07 AM
Have you tried putting it under water whilst pressurising it? As Spartan says, leaking through the pump isn't a problem but leaking out of the air gauge/valve/pipework would be.
I was just trying to ascertain whether it was the action of removing the pump that caused the problem or just a straightforward air leak. Do both valves do the same?
seanreit 05-28-2007 08:30 AM
Those fill valves leak, ask Todd at Dreamworks, they are pieces of junk, originally put out by air pac.
Get the BV fill valve, have worked flawlessly for me for years.
TREADSTONE 05-28-2007 11:25 AM
Thanks Sean,
I am begining to think that way.....but i have one more idea.....I'll nip into work and get some 'Snoop' :)...a liquid especialy designed for leak detection.
Thud_Driver 05-28-2007 11:37 AM
ORIGINAL: seanreit
I've thrown two, one new, one almost new, of those away in the last month because they leaked.
uncljoe 05-28-2007 11:41 AM
FWIW
I've had the gauges leak , check the brass fitting on them..
Semper Fi
Joe
Gordon Mc 05-28-2007 11:46 AM
1 Attachment(s)
ORIGINAL: seanreit
Unfortunately, I've had a bunch of leaks with the BV fill valves. I switched over to the Clippard parts at a fraction of the price, and have had much better luck.
Clippard part # is MQC-3 for the assy including the filler adapter, and MQC-V3 without the adapter. You will need to add a 10-32 screw-in barb too, but it still comes out at less than $3 a pop.
Gordon
TREADSTONE 05-28-2007 01:51 PM
1 Attachment(s)
...:)..Well Found the problem ..or should that be problems...With the aid of some 'Snoop' i found that the steel festo type fitting INTO the Jetronics wsn't tight ..and the the Robart air line i had used to feed into that fitting was'nt sealing properley...The Robart tube is just to floppy to push home effectiveley...
Thanks for all the input guys [sm=thumbs_up.gif]
Brg
Dave.
uncljoe 05-28-2007 02:39 PM
Dave
Where did you purchase the "Snoop"?
Semper Fi
Joe
Spartan Missile 05-28-2007 03:44 PM
So Swagelok are putting soapy water in a squeey bottle and calling it Snoop, I bet it costs £5 a bottle or more.
Is it alcoholic ? at least you could take a swig whilst testing for leaks.
Richard-RCU 05-28-2007 04:01 PM
Dave, If you are trying to connect to a JetTronics unit you will need 3mm line going into the metal Festo type fittings in the valve, instead of the usual 1/8" line found on most retracts, etc. That's the reason it feels like the fitting and line are too loose.
Richard
TREADSTONE 05-28-2007 05:18 PM
Spart...:)....Its very, very inexpensive..;)..It is v.good too, soapy water just dont cut the mustard.
uncljoe...Pm me if you want some..;)
Thanks Richard...I'll get hold of Jetronics...
lov2flyrc 05-28-2007 08:28 PM
ORIGINAL: seanreit
Actually...that is not the case at all. I use these perticular valves in my personal aircraft and while we do have a defective one now and then, they are quite good valves. They either leak from day one or not... I have pressure checked the rest of the inventory I had in stock and only found one unit (out of 78) leaking.
Todd
buddude8 05-29-2007 12:42 AM
I just take a extra fill adapter on these fill valves and solder the end shut. When im done filling i put that one back on. I also put about a 1/2 inch of tubing on the end to designate between my retracts and brake fill
ken
