RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Composite Bandit Control Throws (https://www.rcuniverse.com/forum/rc-jets-120/5943805-composite-bandit-control-throws.html)
Adil Nasim 06-04-2007 02:32 PM
Can anyone tell me what the recommended throws are on the Original Composite Bandit?
Thanks - Adil
Harley Condra 06-04-2007 04:36 PM
RE: Composite Bandit Control Throws
Here ya go...
Elevators: Up 1 1/8", Down 1" measured at the root.
Rudder: 1 3/8" measured at the bottom.
Ailerons: 1 1/8" up, 1" down measured at the aileron/flap joint.
These are high rate deflections....cut the ailerons and elevator in half for low rate, then tune 'em up to suit.
Take off flaps 15 degrees, landing flaps 45 degrees.
Harley Condra
BVm REP
JetCat REP
rcpete347 06-04-2007 04:42 PM
1 Attachment(s)
HI,
Rudder 1 1/4''
elevator 1 1/8''up and 1''down
Aileron, measured at the AIL/Flap joint
normal 9/16''up and 3/8'' down
High rate for windy conditions 1 1/8'' up and 1'' down
CG 8 1/2'' Aft wing root, gear down, tank empty.
Rcpete
Adil Nasim 06-04-2007 04:45 PM
Thank you very much Rcpete and Harley.
Regards,
Adil
Harley Condra 06-04-2007 10:25 PM
Slight Clarification:
CG is 8 1/2" with empty tanks, but with a full UAT, gear down.
Harley Condra
BVM REP
JetCat REP
