Fuel system help
I may be setting up a fuel system with no UAT. What type of special anti bubble felt clunk is best for the header tank?? where can i get one.
TIA, V.. |
RE: Fuel system help
I have used Walbro felt clunks in my gassers but I'm not sure if that's what would be recommended for a turbine as I've only used a UAT or the MAP headers. I got the Walbro at a lawn mower repair center. It't the one with a metal clip holding the felt portion to the clunk and will obviously just clear the standard size opening of a fuel tank(other models are bigger). I've also seen it a Home Depot but it's sold as a package and comes with two other items like engine oil and something else for about ten bucks. Was about three or four bucks seperately at the mower shop .
Marty |
Thanks Marty, i know there are some made for our jets but can`t remember who sells them.
V.. |
Isn't a UAT essentially a header tank ? You don't need a felt clunk or otherwise . Just use a central pickup in the header tank and air won't be an issue .
Marc |
747drvr, i may not be explaining things correctly. I am not really running a "header" tank but straight off one of the main tanks so i am concerned when the tank gets low there is a chance of getting some air.
V.. |
ORIGINAL: Vincent I may be setting up a fuel system with no UAT. What type of special anti bubble felt clunk is best for the header tank?? where can i get one. TIA, V.. Marc |
1 Attachment(s)
Felt clinks aren't recommended for turbines. I know that some have done it without issue, however it is easy for felt particles to migrate from the clunk and plug your injectors or downstream filter.
You can make a pleated filter clunk from an automotive fuel filter. The JPO website use to have a how to set of instructions on their website. For some reason they removed it. They work great and will drain the last bit of fuel from your tank without any air. I still do use a UAT with it, which I make myself using the same filter.. See http://www.rcuniverse.com/forum/m_15...tm.htm#1527831 and http://www.rcuniverse.com/forum/m_20...olution/tm.htm Joe |
That's the element I use . It works well but it will also shed the odd fibre . Maybe not enought to worry about though . I really don't think you need one in a header tank if you have a central pick up.
Marc |
Use a UAT.
| All times are GMT -8. The time now is 06:23 PM. |
