RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   trainer jet help (https://www.rcuniverse.com/forum/rc-jets-120/5966302-trainer-jet-help.html)
339tricolore 06-09-2007 05:51 PM
trainer jet help
1 Attachment(s)
Hello friends , I have the fuel tank 2.120 litres capacity, on my trainer jet p60, end the time on fly is 10 minutes, but I need 4 litres capacity;)[:'(] can I the fuel tanks on the wing?
best regards..
339tricolore 06-09-2007 06:20 PM
RE: trainer jet help
1 Attachment(s)
More pics the fuel tank..
Wayne22 06-09-2007 08:17 PM
bad idea for several reasons....
-2 more litres of fuel is going to add a lot of weight to your jet which you have to pack around for the whole flight
-the extra weight will increase the wing loading, and make the plane a real slug to fly until a substantial amount of fuel is burned off.
-the extra wingloading will increase the stall speed, and may well increase the risk of a takeoff accident, or a high speed stall
-without a pump in each wing tip tank, there is no guarantee that they will empty completely, or evenly (even that is no guaranty)
-if one tank emptys more than the other, or you have one that refuses to empty, you are going to have a lot of difficulty keeping the wings in trim, and may run out of aileron control.....
10 minutes is not a bad endurance for a jet..just land, check everything over, refuel and go fly again...............
339tricolore 06-10-2007 11:01 AM
1 Attachment(s)
HI, Wayne22 thanks for your repley..but I not have alternative ..;);)here is the my wing..is very strong;) ho sorry I have 0ne idea.
Best Regards
hmjets 06-10-2007 11:35 AM
It is better put a center line tank!
