RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Aftermarket ECUS ??? (https://www.rcuniverse.com/forum/rc-jets-120/6024475-aftermarket-ecus.html)
John Casey 06-23-2007 02:15 PM
So anybody start producing aftermarket ECUs for engines yet?
maybe a universal ECU you just program your engine values into?
It would make things easier to "standardize" the aircraft with.....
Any suggestions?
Anything new coming in this area?
jason 06-23-2007 04:15 PM
RE: Aftermarket ECUS ???
I think Gaspars FADEC is the nearest you will get to a DIY program yourself ECU. I think they can supply them unlocked so you program things like starter motor voltage, the temp gas turns off and what RPM to turn the starter off. All the things you can't normally get into with most ECU's.
Jason
TREADSTONE 06-23-2007 04:18 PM
ORIGINAL: John Casey
..maybe a universal ECU you just program your engine values into?
...Like number of starts & Run times..:)
scraper 06-24-2007 12:26 AM
There have been aftermarket ECUs around for years, Fadec, gb hobbies...
JohnMac 06-24-2007 03:23 AM
Orbit, Jettronic, Mini Hobby........
The Flying Scot 06-24-2007 03:53 AM
I was in contact with Orbit last week and they can no longer supply their ECU as it is now the ECU used with the Graupner Booster engines.
I think ths only leaves the Gasper Fadec.
Arthur
GSR 06-24-2007 04:54 PM
Sandor has one that looks pretty good from the specs-give it a look. Scott
i3dm 06-24-2007 05:17 PM
i really like my GB hobbies ECU - its fitted to my JJ1400 turbine.
digitech 06-25-2007 04:43 AM
i will bring our latest kerostart version prototype to the WJM ireland
installed on a Ulysses..
The Flying Scot 06-25-2007 06:00 AM
Sandor
Does it use optical or magnetic sensor for RPM measurement? Will I be able to use it on an old simjet 2300?
Arthur
digitech 06-25-2007 07:01 AM
ORIGINAL: The Flying Scot
Sandor
Arthur
i can fit one of those in 30 minutes on a Simjet 2300;)
sensor is magnetic , like simjet.
Spartan Missile 06-25-2007 07:04 AM
ORIGINAL: digitech
Sandor,
magnetic - magnet in compressor nut ?
-or-
hall sensor, counts blades ?
Thanks ?
digitech 06-25-2007 08:58 AM
ORIGINAL: Spartan Missile
ORIGINAL: digitech
Sandor,
-or-
Thanks ?
Simjet used on most models 2 magnets inside the compressor positive-negative.
on newer models they changed to magnet in spinner nut.
but we can also adapt your AMT signal if you want ,we also have deviders ;)
John Casey 06-26-2007 03:39 PM
Start and run times.?????..........
ECU data is hardly any indication of the condition of any jet engine good or bad.
It won't tell you that the engine was run through the trees,and crashed
in a COMP arf mig 15 in Delray beach florida, by an englishmen, with witnesses,
and then ponded off to someone. in California... with grass stains
and bent compressor blades...... as newly factory rebuilt and never flown.
heck you can zero time
a jetcat ecu just by holding the menu button down for 1 minute till all the leds all flash together
(at least on the older models) wiping out the run times.
thanks for th input guys...
digitech 06-27-2007 05:39 AM
in a COMP arf mig 15 in Delray beach florida, by a fellow englishmen, with witnesses,
I will check into the Gasper Fadec.
The AMT 280 has magnet type rpm sensors as well.
you forgot 2 important items:
most manufacturers can tell you about the owner history
powerfull forum where almost everyone nows each other
John Casey 06-27-2007 12:49 PM
Thats very true........... as since I'm a buyer of turbine engines
and usually the one getting screwed by some unethical SOB (only 1 out of 10 buys so far)
and having to pay to fix the engine someone ripped my off on.....
and not a seller of turbines.....I've had no trouble using this forum
to track down what engine was in who's aircraft when they
ran it through the fawna and into the terra firma...... crash news travels fast.
It would be great to have an engine database of serial numbers,
aircraft accidents, what engines were in those aircraft as so the jet engine
" Buyers" won't get screwed buying a FODed out engine.
It could be part of the safety officers report to the AMA,
and if your shown to be crashing alot of jets..
the AMA could pull his turbine wavier and save the "rest of us" responsible pilots.
Yes I needed to vent, a little......
But back to ECU's........ anybody got a Page for Gaspars FADEC that works?
