RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Servo Exerciser?? (https://www.rcuniverse.com/forum/rc-jets-120/6156166-servo-exerciser.html)
Undecided 07-25-2007 06:24 PM
Servo Exerciser??
I have a new set of servos that I want to bench test or burn in. Who makes the best servo Exerciser or tester that will run a servo from stop to stop over and over to test for premature failure?
Thanks, Neal
Bob.R 07-25-2007 07:18 PM
RE: Servo Exerciser??
I've used a JR Matchmaker for that purpose. Great for servo installation and setup as well.
David DeWitt 07-25-2007 09:51 PM
Vexa Control Servo Exerciser http://www.vexacontrol.com/
OldRookie 07-25-2007 09:53 PM
Check this one out.
It does about everything, with lots of bells and whistles.
I have the early model they made before this, and have had nothing but good luck with it. Once you get a servo exerciser you will wonder why you didn't buy one earlier.
http://www.vexacontrol.com/xciter_details_1.html
Greg
BCoston 07-25-2007 10:04 PM
Neal,
I have this one, would you like to borrow it? The rental fee will be very reasonable!!:D
http://electrodynam.com/rc/EDR-203/index.shtml
warbird51 07-26-2007 12:38 AM
I bought this one 3 or 4 years ago and I always "run" in any new servos before they go in a model
It's great!!!
Wayne
ORIGINAL: BCoston
Neal,
TommyWatson 07-26-2007 01:41 AM
Futaba make one. It is called 9ZAP
Ehab 07-26-2007 02:17 AM
The vexa is a good one. Also, the Hitec programmer can be used for your needs too on all servos. You also may want to consider adding some load on the servo in test!!!
djindivik 07-26-2007 04:01 AM
My Futaba FF9 TX has a built in one. Just turn it on & it sends all the servo's full throw in each direction, till you turn it off. Ray
ChuckC 07-26-2007 08:17 AM
I burn mine in on the benchtop free from linkages with a Hitec programmer plus an ammeter in line. This way I can chart the voltage and amps when new, at the end of burn in and then again once it goes into the model to indicate quality of linkages.
I also follow up with the same measurements once in a while before flying to keep a check on the health of things.
You do wonder how you ever got along witout it.
causeitflies 07-26-2007 10:09 AM
I use the Hitec programmer or my Evo radio.
dw_crash 07-26-2007 10:14 PM
I use the ElectroDynamics one. It is the cat's meow!!!! I would not build without it. Best $40 bucks I ever spent.
DW_Crash
SinCityJets 07-27-2007 01:45 PM
1 Attachment(s)
This is a unit we sell. It does both do servo centering, and in "Auto" mode, it will cycle the servo back and forth. You can even adjust the rate at which the servo moves faster and slower.
ianober 07-27-2007 04:01 PM
I have used the Hitec one with great success, solid unit!!!
[link]http://www.hitecrcd.com/servos/show?name=HFP-10[/link]
Dave Kelly 08-02-2007 07:31 AM
Hi ,
SM services do a great cheap tester in the UK sm41 is the part number.
http://www.smservices.net/acatalog/Test_Units.html
I have included the web address because if you google S M you will get a few surprise non related subjetc matter hits!!!!
brgds
Dave
