RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Servo--Rx Breakin ideas please. (https://www.rcuniverse.com/forum/rc-jets-120/6169485-servo-rx-breakin-ideas-please.html)
Sonicwings 07-29-2007 06:53 AM
Hi all,
What process do you go through with Running in new servos, and Recievers before putting them in a new jet model ???
I have a servo test and cycler from Graupner, have run servos on the bench with this for half hour in the past--- but not sure whats best--- i have a bunch of Futaba servos to run in my new Rookie 11, and a bunch of JR for my boys Baby Boomerang---
All ideas greatfully recieved.
cheers Jay.
Chris Smith 07-29-2007 08:15 AM
RE: Servo--Rx Breakin ideas please.
I have never heard of a radio manufacturer requiring servos or recievers be broken in when new. I just use an amp meter during instal to insure they don't bind.
Chris
Doug Cronkhite 07-29-2007 09:51 AM
I NEVER run brand new equipment in a brand new airplane. Put them into a real beater to fly them and ensure they're functional. Phil Kraft used to do this on everything he built with the airplane that eventually became the Ugly Stick.
HAMMERDOWN 07-29-2007 10:38 AM
I used Kraft radios in the early seventy's but things have changed a little since then. 40 years ago you had to break in a car very carefully and adjust the valves every 3000 miles. Who are we to second guess the mfg? If you don't trust the directions I wouldn't use the product. (IMHO)
djindivik 07-29-2007 11:23 AM
I started flying single channel in the mid '50's, & i still have a Matador Midas 10channel reed outfit with 5 Bonner duramite servo's, that still work. Over the years i must have used several hundreds if not thousands of servos. This is the first time i have ever heard of 'Breaking or running in' of servos, & have never ever done it, never heard of anyone doing it, nor been instructed to do it by any manufacturer. Do you guy's just look constantly for something to worry about ? (I have just put my tin hat on), to protect me from the showers of abuse & BS about to come my way. He he. I love a good debate.
Ray.
GSR 07-29-2007 12:05 PM
If an electronic part is going to fail it will usually fail in the first 30 mins of use. I really doubt that the manufactures test the servos for this long. Its really no big deal give the servos a test -Most of us do it without even knowing it when we set the models up the elecronics get a good workout on the bench. If you have JR you can use the servo test function and let them run for a bit.Just remember that you really cant do it in the model- in this mode the servos drive to the full travel and you would probably overtravel the setups. Scott
squirt! 07-29-2007 12:15 PM
ORIGINAL: Sonicwings
Hi all,
I put 4 screws through the holes and make sure they are tight...
highhorse 07-29-2007 01:20 PM
[link]http://www.vexacontrol.com/xciter_details_1.html[/link]
I HAVE (!) read of others breaking in servos. Read it right here in the jets forum. I think that "breaking in" is not the correct term though. The intent is to thouroughly bench TEST the new equipment, finding the occasional bad apple before you lose a 10K airplane to a 100 dollar servo with a bad gear!
The above link is to an interesting looking toy that will test servos on the bench and aid in setup too.
RAMFlyer 07-29-2007 04:01 PM
1 Attachment(s)
I ALWAYS, ALWAYS, ALWAYS cycle (break-in, burn-in) new servos for at least 30 minutes using an old ACE Servo Cycler. Have found a few over the years that went belly-up during the burn-in.
I ALWAYS, ALWAYS, ALWAYS fly a new receiver, or one that has been in for repair or checkup, in a bird I keep just for that purpose. Also check out the transmitter after repair or checkup the same way. Have found some bad crystals and one bad receiver this way.
Call me overly cautious, paranoid, or whatever but I have never lost a plane to a servo or receiver problem. Dumb thumbs usually does them in...
(Edited due to being a lousy speller......)
SinCityJets 07-29-2007 04:07 PM
1 Attachment(s)
Here's one for half the price.
j.duncker 07-30-2007 04:22 AM
I use the Kraft route. Stick the gear in a hack and fly it. I like to be confident in my RC gear so if something untoward happens in the first few flights of a new model I can be reasonably confident that it is not the RC components, maybe the installation but not the gear.
Incidentally in all the years of doing this [30+] I only found a couple of twittery servos and one glitch prone receiver.
Ron Stahl 07-30-2007 04:58 AM
I keep an old beater trainer to put new RX's and new TX's in for at least an hour of flying before they go into anything new. I bench test new servos for the same hour as well. Doing this for over 30 years I have never had a servo fail to date in a plane. I have had two servo ever fail on the bench and they were in the past year both Jr servos one a 241 and the other a car steering servo forget the number and only one RX fail later and that was at least 15 years ago;It was a first gen Futaba FM forget the model number. Remeber nothing is perfect though.
Woketman 07-30-2007 06:22 AM
RAM & Ron are correct: you gotta be nuts if you fly a high $$$ turbine bird with new, unproven equipment!!! REALLY!
ALWAYS verify that the servos & reciever function (with a load for servos) for some initial burn-in period. For servos either a loaded bench check or flying in a well worn turd-plane.
Silver182 07-30-2007 06:24 AM
Hi all,
cheers Jay.
Put the receiver in the freezer overnight. Quickly while it's still cold fire it up and check it out. That test usually will tell you if there is an installed component that is out of tolerance. Then a vibration test, and finally the good ol swamp & range tests... test the servos the same way same time. Then I do a stall test with the servos to see if the servo amps will hold up to a few stalled moments.
After the new stuff passes these tests then fly it in a beater... I like to keep my beaters for next time!
Lee
