EDF F4 Phantom
Does any one knows a site with an EDF F4 Phantom? I would really appreciate your help.
Thanks in advance. Warboy |
RE: EDF F4 Phantom
http://www.electricjetfactory.com/
Here ya go Warboy Look in the 70mm jets ... HET make a nice looking F4 robert is a great guy to deal with... good luck Ronnie |
RE: EDF F4 Phantom
If your looking for a large F4 with twin 90mm fans look here:
http://www.ductedfans.com/jets_conversions_f4.html This conversion is based on the Yelow Aircraft F4 and used Schuebeler 90 mm fans. I can tell that the model flies extremely fast and has phenominal vertical power too! Yet it lands very slow as it's finished weight is on average 2 1/2 lbs lower than it glow powered sibling http://www.rcgroups.com/forums/showthread.php?t=332845 Bob |
RE: EDF F4 Phantom
Or stay tuned to RCU. Me thinks you will see something big soon.
RE: EDF F4 Phantom
So Tam is working on a EDF version of his new F4.
RE: EDF F4 Phantom
ORIGINAL: R_Belluomini So Tam is working on a EDF version of his new F4. Barry had my first proto type doing the inlet ducting. This will be 90mm twin set up or single P-70 turbine. |
RE: EDF F4 Phantom
Just a guess Tam. What scale are you doing? I am going to build another one myself.
It will be lighter and 100% scale and it is going to be all mine baby and this time "NOT ebyding for sale baby"! |
RE: EDF F4 Phantom
Thanks guys because I already ordered the 90mm plane, and it will soon arrive.
Thanks. Warboy |
RE: EDF F4 Phantom
What airframe did your order?
Bob ORIGINAL: Warboy Thanks guys because I already ordered the 90mm plane, and it will soon arrive. Thanks. Warboy |
RE: EDF F4 Phantom
I Ordered the
70mm Phantom |
RE: EDF F4 Phantom
ORIGINAL: tamjets ORIGINAL: R_Belluomini So Tam is working on a EDF version of his new F4. Barry had my first proto type doing the inlet ducting. This will be 90mm twin set up or single P-70 turbine. |
RE: EDF F4 Phantom
Is their anything new on this? How Longis the wait , How Much? which nose?
| All times are GMT -8. The time now is 06:49 AM. |
