RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   DS3301 or DS168 (https://www.rcuniverse.com/forum/rc-jets-120/6449179-ds3301-ds168.html)
SinCityJets 10-04-2007 12:42 PM
DS3301 or DS168
For the rudders on the Velox. I've seen conflicting opinions. What's the main diff?
SinCityJets 10-04-2007 05:25 PM
RE: DS3301 or DS168
Any and all opinions welcome.
scaleMan 10-04-2007 06:16 PM
RE: DS3301 or DS168
Well, I don't have the answer on which is better but I used the 168's with those nifty mounts from Todd... They fit and work great for me...
mr_matt 10-04-2007 06:33 PM
RE: DS3301 or DS168
DS168 is about 1/2 the width give or take. I would use it only if I needed the narrow width. In my experience those crazy narrow servos have weaker gears but maybe the 168 is different, I don't know.
I have used the DS3301 on several occasions and I like it a lot. I think it is spec'd on the BobCat for rudder.
SinCityJets 10-04-2007 07:38 PM
RE: DS3301 or DS168
Yah, I need it for the rudder of the Velox.....just trying to decide between the two!
lov2flyrc 10-04-2007 08:42 PM
RE: DS3301 or DS168
Actually.... The DS168 has a slightly more durable gear train than the 3301 but, both good servos.
Cant go wrong with either for this application, basically even on torque and I have had good success with both on rudders. the 168, due to the metal gear train will handle the the occasional bump a bit better but, still a nylon drive gear off the motor.
Flip a coin :D
SinCityJets 10-04-2007 09:26 PM
RE: DS3301 or DS168
Thanks Todd, now if you just knew the answer about the gear!
