RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Bvm Aggressor 1 (https://www.rcuniverse.com/forum/rc-jets-120/67015-bvm-aggressor-1-a.html)
vinnyjet 03-02-2002 06:41 PM
Bvm Aggressor 1
LOOKING FOR ANY INFO
CG/FLIGHT SURFACE MOVEMENT/FLYING TIPS/GOOD FLYING
WEIGHT/PLANE HAS BRAKES AND FLAPS
THANKS
VINNY
Bobman 03-02-2002 08:05 PM
Bvm Aggressor 1
Vinny,
I'll dig out my construction manual tonight. Should have it still. Good flying plane, I believe 10lbs was about normal. Flaps were really useful in bleeding off speed for landing 'cause those things are pretty clean.
Bobman 03-04-2002 01:04 AM
Striking out...
Can someone else help Vinny out here? I'm not finding my manual under all the piles of sawdust down in the shop. ;)
Bob
Yale 03-06-2002 01:41 AM
Same Problem
Lost battery in transmitter,Lost all controls,Do not have manual
Do not know the throws for controls,any help,thanks in advance
Sidewinder1 03-06-2002 02:40 AM
Bvm Aggressor 1
:p Aggressor 1 / Sport Shark control settings from 1986 manual:
Flap - 30 Deg. (measured at upper surface, use flaps on landing only)
Aileron - 1/2" up, 5/16" down (measured at T.E. adjacent to flap)
Elevator - 1/2" up, 3/8" down (at T.E.)
Rudder - Not specified
C.G. - 2 1/ 2" behind leading edge of belly hatch (works out to 5 1/2" back from L.E. at upper surface root).
Note: It is recommended that the model be set up for balancing with the landing gear extended and fuel tanks empty.
Weight should be about 10 lbs.
I would be happy to send you a copy of the manual if you e-mail me. BV has some good information on flying tips.
Tom
Sidewinder1 03-06-2002 11:40 PM
snail mail
Vinnyjet and Yale:
:) You have snail mail!
vinnyjet 03-07-2002 01:25 AM
bvm aggressor1
tom and bob
thanks for all your help
vinny
Yale 03-07-2002 03:24 AM
lots of thanks
I sure want to thank you Sidewinder
Sidewinder1 03-07-2002 03:54 AM
No problem
1 Attachment(s)
Here is my Aggressor 1.
Bad lighting, but since been painted in Navy colors.
Awaiting flying weather. :)
Tom
Yale 03-13-2002 01:38 AM
manual
SIDEWINDER
Many thanks,You are a Great ONE for the hobby,We need more like you even every day living,have good flying Yale
