RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Turbine bypass (https://www.rcuniverse.com/forum/rc-jets-120/6747643-turbine-bypass.html)
poussard 12-12-2007 01:02 PM
Turbine bypass
can anyone tell me the pros and cons of using the bypass for turbine engine
Kevin_W 12-12-2007 01:49 PM
RE: Turbine bypass
Pro's
1. Less drag, smoother airflow through the inside of the airplane than a non-ducted installation.
2. Cleaner install (if done properly)
3. Less chance of equipment inside the plane coming into contact with the turbine (either fod in the intake, or melting onto the side of the case).
4. More protection for the turbine in a crash
5. Might also help avoid having fuel spray come in contact with hot engine parts in some crashes (less chance of a fire)
6. Easier for inexperienced builders to set up a bypass system that is pre-engineered without making mistakes.
Con's
1. More difficult turbine access.
2. Much more difficult to scratch build using a bypass because the ducting and fuel tanks need to be designed and built to fit the airplane.
3. After engine shutdown the radiant heat from the turbine will be contained inside the bypass, necessitating the use of a fan to help with cooling (yes I realize this is a good idea even if you don't run a bypass, but it is pretty much mandatory with one).
4. Takes up more space inside the airplane.
5. Higher cost.
6. Some propane start turbines are more likely to "BANG" on startup inside a bypass (usually doesn't hurt anything, but it gets everyone's attention).
I'm sure there are more on both sides...
BirdofpraY 12-12-2007 03:25 PM
RE: Turbine bypass
inside a bypass your get dynamic thrust. If you want speed this is the way to go...
no bypass you get greater static thrust. If you want 3D performance this is the way to go...
CARS II 12-12-2007 04:14 PM
RE: Turbine bypass
How about
Without the bypass ( or at least without the top of it ) air now flows into the engine ( front and back ) then the pipe making the opps. cooler at all times because the air is in motion and not trap or restricted by the top of the bypass.
My 2cts. [8D]
seanreit 12-12-2007 04:29 PM
RE: Turbine bypass
FWIW, having read almost every thread posted in the jets forum over the past 6 years, Kevin's response above is about the best answer that has ever been posted on this topic, and in my opinion, beyond the obvious (which Birdofpray chimed in with [although there are some that would disagree] regarding static and dynamic thrust) Kevin's response provides enough detail that I would point people to this thread in future discussions of this.
Well done!
KC36330 12-12-2007 05:12 PM
RE: Turbine bypass
a wet start isn't as easily seen in a bypass installation :)
Kevin_W 12-12-2007 05:47 PM
RE: Turbine bypass
ORIGINAL: seanreit
Well done!
OK Sean, what do you want now? :):D
seanreit 12-12-2007 05:53 PM
RE: Turbine bypass
We'll talk at Austin, but those tire molds you made are going to be heavily discussed, I'll bring the beer!
Kevin_W 12-12-2007 05:58 PM
RE: Turbine bypass
ORIGINAL: seanreit
It might take more than blowin smoke up my arse and beer for that! LOL
Bring Captain Morgan. :D
tp777fo 12-13-2007 08:57 AM
RE: Turbine bypass
Add to the PRO: Quieter
SpiderJets 12-14-2007 04:04 AM
RE: Turbine bypass
1 Attachment(s)
ORIGINAL: KC36330
Mine are transparant ! (On the pic below this SpiderJets turbine bypasses are cut off at the rear to fit with the standard bellmouth of the JetLegend L-39...)
No heat issues, even with this JetCat P-160 installed.
I still have some stocks... PM me if interested...
Nicolas.
MaJ. Woody 12-14-2007 06:33 AM
RE: Turbine bypass
Transparent is NICE!!
Dom
