By-Pass Question
I have a Skymaster F-16 1/6. Getting ready to maiden any day but have a question. I was only going to use the bottom part of the bypass as a shield when someone told me that I should go ahead and use the upper part to.
Question: The bypass bumps up to (touches) the thrust tube bell house. Should I cut it to match the distance of the turbine from the tube or just keep it. It covers the tailpipe of the turbine. Thanks, Andy |
RE: By-Pass Question
I vote for using the entire bypass. In my Avonds F-16 he specifically sez to not run the motor at high power setting without the top of the bypass to keep from collapsing the pipe. I dont want to experiment to find out if it matters. I personally think it will help the airplane with the bypass as the airflow will be cleaner through the motor vs the turbulence through the fuselage without it. I think they have lots of advantages for very little work.
ORIGINAL: tp777fo I vote for using the entire bypass. In my Avonds F-16 he specifically sez to not run the motor at high power setting without the top of the bypass to keep from collapsing the pipe. I dont want to experiment to find out if it matters. I personally think it will help the airplane with the bypass as the airflow will be cleaner through the motor vs the turbulence through the fuselage without it. I think they have lots of advantages for very little work. |
There should be no gap at all between the bellmouth and the aft end of the bypass.
They will get hot during a static run, that's normal. In flight they get the airflow to cool them down. I really dont thing the gap is a big issue as long as the bypass is securely attached and the turbine exhaust is centered with the tailpipe. A picture would help
1 Attachment(s)
ORIGINAL: tp777fo They will get hot during a static run, that's normal. In flight they get the airflow to cool them down. I really dont thing the gap is a big issue as long as the bypass is securely attached and the turbine exhaust is centered with the tailpipe. A picture would help Here ya go: The best one I could get. Its not mounted just laying on top of the motor. Thanks again for all of your help. Andy |
I would not use it the way it is in the photo. Does your engine line up with the tailpipe? ie- center of the enigine= center of tailpipe.
1 Attachment(s)
Yes it does. The bypass doesn't match the circumferance of the bellhousing. It's warped as you can see.
See pick. |
| All times are GMT -8. The time now is 06:44 PM. |
