Only 127,900 LBS Of Thrust
a little TiVo on the GE90 115B
[link=http://www.fileden.com/files/2006/9/12/215757/GE90115B.wmv]Click To Play[/link] the hail test is [X(] |
RE: Only 127,900 LBS Of Thrust
Why does that sexy new blade draw in more air then a conventional straight chord blade?
More area reaching out beyond the norm of the conventional blade? |
i dunno, but if we could get a few of them put on a JetCat................
great engine, thanks for sharing. Joe C!!
I wish I could watch it, but God forbid my computer actually work.[:'(]
@Speed Junkie, I just did some research, and read that the fan blades are specially designed to operate at low rpm ( around 2500 rpm ) so it moves the same ammount of air as a conventional blade running at a higher speed. This lower speed allows it to meet all noise requirements. |
That is incredable
Just by contrast...in 1968 - 40 years ago- the first JT9D, the biggest jet engine in the world at the time (designed for the B747) flew its first test flight and developed a whopping 43,500 lbs of thrust
Impressive engine, I guess they can fly the 747 as a twin now!:)
Sara,
Do you have a FOD screen that will fit this? Thanks, Don |
I flew on a 777 and it vibrated like no other jet I have been on..
They need to put 3 of those monsters on the back of flying wing with 1000 head of cattle on board... hahaha Eddie |
Eddie,
They probably forgot to "Locktite" the bolts that hold the turbine to the plane! [X(] Don |
1 Attachment(s)
Thanks for the cool vid . I can attest to the awsome power these engines can produce ! My new ride is the 777-300/ER and 200LR . Amazing machines !
Marc |
....127,900 Lbs ?.. The GE90-115B Max Power at Sea Level is rated @ 115,300 Lb.......Or does it have a reheat version...:) |
ORIGINAL: TREADSTONE ....127,900 Lbs ?.. The GE90-115B Max Power at Sea Level is rated @ 115,300 Lb.......Or does it have a reheat version...:) can only go by what the lady said as being 'Most Recently'. |
115,300 Lbs of thrust at Sea Level is the Flat Rating, hence GE115BL (the 115 stands for the Flat Rating Thrust Available), however with a plug change to the Fuel Control Unit the engine can produce more thrust.
At a Sea Level Airport with standard pressure (1013.25 Millibars) the engine will produce 115,300 Lbs of thrust until the ambient temperature exceeds about 28 degrees celcius, meaning that below this temperature the engine is Flat Rated. It's always better to reduce the thrust on all jet engines as much as possible (of course maximum thrust is always available in an emergency), but we very seldome do full rated thrust takeoffs. How we do this is to input an assumed ambient temperature into the FMC (sometimes as much as 75 degrees celcius), the engine now thinks that the actual ambient temperature is 75 so it limits the thrust. Don't want to be too technical, more of a laymens answer. Cheers, Darryl Tarr, Captain Boeing 777, Emirates airline |
Thanks you Darryl,,,,,,,,,,,,,,,,,,,, very well explained for the layman
Dave |
ORIGINAL: darryltarr Darryl Tarr, Captain Boeing 777, Emirates airline Or was I on just on too much crack that day… ? Eddie |
1 Attachment(s)
[quote]ORIGINAL: EddieWeeks ORIGINAL: darryltarr Darryl Tarr, Captain Boeing 777, Emirates airline Or was I on just on too much crack that day… ? Eddie Crack Kills |
1 Attachment(s)
Hello Eddie,
They growl and rumble a lot during the start procedure, but after stabilization they are as smooth as silk throughout the flight envelope. I think this airplane has a very bad crack in one of its windows. Cheers |
ORIGINAL: Wayne22 Just by contrast...in 1968 - 40 years ago- the first JT9D, the biggest jet engine in the world at the time (designed for the B747) flew its first test flight and developed a whopping 43,500 lbs of thrust And the A-380 with four of the 'baby' 777 engines on it, pretty amazing. The 777 variant engines are pretty cool looking, but the big -300ER versions are just monsters. Wise cracks about 2 engines going on strike during short final not withstanding. Engine technilogy has long been the bottleneck of aerspace development, it's pretty cool to see the development these days, bit by bit. |
ORIGINAL: Eddie P ...Engine technilogy has long been the bottleneck of aerspace development. Its not the engines that are holding the 787 back... |
| All times are GMT -8. The time now is 01:19 AM. |
