RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   schubller ducted fan (https://www.rcuniverse.com/forum/rc-jets-120/759064-schubller-ducted-fan.html)
crazyjim-RCU 05-09-2003 04:40 PM
anyone have experience with the Schubeller ds-51-dia-3ph
ducted fan? Is it worth the money for the power?
uncljoe 05-09-2003 05:10 PM
All my large electrics use this fan ......."Schubeler " Lear , Me 262 & f9f . Is it worth it....Yes IMO,
Semper Fi
Joe
bruff 05-09-2003 09:00 PM
Yes, I have a set going in my Airworld ME-262. They are the BVM of Electric ducted fans. :)
Bob
crazyjim-RCU 05-09-2003 11:05 PM
schubler fan
Whalecrew and Bruff
:) Thanks for the info. I am thinking of putting it in a B66 and want to buy the right fan unit the first time.
What motor and speed control are you using?
F3D2Q 05-09-2003 11:54 PM
crazyjim
Me 262 #1 plettenburg hp220.30/A4sp/schultz bo55 44 cells
Me262 #2 Hacker hs18xl jep1 70 3p 44 cells
Lear Hacker hs 16 s jep1 70 3p 32 cells
F9F hacker hs 16 jeti 70 3p 16 cells
Semper Fi
Joe
skywarrior(A3D) is a great plane... had a few rides in them, flew in the original Whale.... F3D 2 Q skyknight
Vincent 05-10-2003 12:09 AM
Schubi`s
Crazyjim,
You can get loads of info over at e-zone on that fan. The Schubi is the best there is, 5 month wait tells you something. You need to spend money for performance in EDF. Uncle Joe and Bob Ruff are into it and can help you decide. You can spend as much as it would cost to buy two wren 54 turbine kits!! for your B-66 project.
Vin...
bruff 05-10-2003 01:42 AM
Setup
My ME-262 is using Hacker B50-16L, Master/Jeti 77 AMP ESC and 22 HV 2600 ma cells. Should be in the 1200 Watt area per motor.
Bob
crazyjim-RCU 05-10-2003 02:53 AM
schubler fan
Thanks everyone its' time to buy and build
stefanP 05-11-2003 01:23 PM
Jim, just remember there is a two month waitning list for this fan :eek: So you better get on Dieter's waiting list!. I just did :D MAY THE THRUST BE WITH YOU!! stefanP
hoser 05-11-2003 04:07 PM
I see an e-thread here, ok guys what noticeable improvements did you notice when you switched to the schubi ?
Time, speed ?
considering ordering one for my mig-25
uncljoe 05-11-2003 05:32 PM
Jose
1 Lighter
2 Plane seemed to get on step earlier
3 little longer run
4 comes balanced
5 Had the mega $$$$$$$
Semper Fi
Uncljoe
Vin is right two Mw 44 might be cheaper
rpz-RCU 05-11-2003 09:17 PM
A little off topic, but...
Just a little off of the main thread, but does anyone know where I can come up with a 3 inch (or thereabouts) fan unit? I'm trying to put together a twin... 5"+ fans would make this way too big.
stefanP 05-11-2003 11:09 PM
Randy the most common used is wemotec. www.wemotec.com The schubeler fan that is being disgussed here is from,www.shredair.com If your on a budget you stay toward wemotec.If $$$ isn't a question then the schubi fan is the way.As for U.S. source's for wemotec,Kirk at Newcreationsrc.com or eam.com are a good starting point.Also you can jump over to the ezonemag.com go to the jet forum.have fun,stefanP
P.S. Hi Uncljoe &hoser :D
rpz-RCU 05-12-2003 02:08 AM
Thanks Stephan... I have been looking at the WeMoTec, but was unsure if they were good for piston use.
Many thanks.
bruff 05-12-2003 04:56 AM
WeMoTec
WeMoTec are not good for glow use only electric. The only two fan that are glow that size is the Kyosho 90 mm and the Tokin fans. Both are set up for .15 to .18 size motors.
Good Luck,
Bob
