RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   PMP Tuned Pipe O-Ring? (https://www.rcuniverse.com/forum/rc-jets-120/7658680-pmp-tuned-pipe-o-ring.html)
jimm 06-25-2008 07:17 AM
I run a old PMP tuned pipe in my TGA F-15 with a OS 91. It has the stock OS exhaust manifold and I don't remember what the type and number the O0rings are for it. Does anyone who might still run one or had one know what O-rings I need for it?
Jim
GrayUK 06-25-2008 07:20 AM
RE: PMP Tuned Pipe O-Ring?
They are viton o rings, i may have a few around, if not i should be able to give you the details.
Paul
Thud_Driver 06-25-2008 11:05 AM
I always used Viton #116 orings, part number 9464K29 at mcmaster.com, $8.03 for 50. As I recall, I used 2 on the OS header.
jimm 06-25-2008 11:44 AM
Great, that is what I need to know. Thanks for all of your help.
Jim
gazza3535 06-25-2008 03:47 PM
Yes they are Viton, but they are "D" rings as opposed to "O" rings
GrayUK 06-26-2008 06:47 AM
No
They are not D rings, they are O rings.
2 on a standard OS header.
Paul
Thud_Driver 06-26-2008 12:57 PM
The original seals that came with the OS header were wide and flat, maybe "D" shaped. They're a bit pricey to replace so I used 2 of the Viton o-rings as replacements. Sometimes it helped to clean up the slot on the header with a needle file as the casting left some flash. The fit with the o-rings can be really tight, depending on the pipe, so you may have to lube the o-rings a little to get the pipe on.
GrayUK 06-26-2008 01:51 PM
The PMP pipe was designed to do just that.
It used a standard OS manifold and 2 viton o rings.
( I know cos i designed it) ;)
Paul
gazza3535 06-26-2008 02:38 PM
Sorry i misunderstood the question with regards to the pipe being used, I wrongly thought that all the pipes would use the standard OS "D" ring on the standard OS exhaust stub
stick08 09-28-2011 06:48 PM
1 Attachment(s)
Hi Paul,
I used always your PMP pipe and O ring system now I am flying a Spectre ( look my last post here ) and broke the two PMP pipe I had, where can I found these pipe plus the 2 black O ring , the bumper ring , the expoxy part that fit between the manifold and the pipe, also I never found exactly where you attach the pipe with the big O ring at the end of the pipe or at the middle near the balance point ?
I also have a weston uk inox short pipe but need the O ring ( they are smaller than those needed on your pipe )
thank you Paul ( if you are Paul Gray the maker of these nice and good pipes )
Daniel
http://www.youtube.com/watch?v=nZxr19fO-Cw
http://www.youtube.com/watch?v=Jk8ri...eature=related
