A killer detail
1 Attachment(s)
This saturday I was about to make the first flight of the day on the F-15I and when I checked the commands while taxiing for takeoff I found something strange .. while the elevator throw seemed fine, the aleiron movements looked like 1/3 of the usual travel!
Ok, I aborted the flight, shut off the engine, and checked for the dual rates, atv´s, mixes looking for something that could made this happening.. nothing was found, and after doing this the elevons travel returned to normal! of course I packed everything and didn´t flew that day (it was a spectacular sunny saturday here.. a real pity). Later at home, as the problem was happening in a elevon setup, I discarded a problem in the airplane.. so I disassembled the radio (a Futaba 9C) and found this killer detail: The yellow wire (signal) from the aleiron stick potentiometer was almost broken!!! (sorry for the cell phone crappy pic, but you can see a spot in the wire, as the broken part). This broken wire was messing up the voltage reading from the potentiometer, and almost cost me a plane.. fortunately I was lucky again and didn´t crashed the F-15. A interesting thing is that this radio is not old at all (bought it in 2005) and it was not heavily used. So, I have a suggestion for everyone reading this: 1) Check the flying surfaces carefully before every flight. (not just moving them.. watch very carefully if something didn´t look right) 2) Check for the TX potentiometer wires if you have a Futaba radio bought earlier than this or about this same year.. of course, sending the radio for a checkup could be a good idea. I also suppose that this applies for any brand... Hope that this may help someone, Enrique |
RE: A killer detail
you're right - it is a crappy pic!! :D:D
Good thing you decided to pack up and check it out at home... |
RE: A killer detail
You have been living right! Your karma is excelent to still have that plane! Enrique, could you tell how/where the wear (abrasion?) happened? I have been impressed with the workmanship of Futaba radios, so I am suprised it had this abrasion. |
RE: A killer detail
absolutely... It was disappointing at the moment, but it was the right thing to do.. much better than posting here a crappy picture of a meteor crater instead.. ;)
RE: A killer detail
Good call Enrique, crappy picture for sure but, now I will have to take mine apart to check the wires in my 9C, I have seen this before in Futaba radios.
RE: A killer detail
Matt, I guess that I had lot´s of luck until this moment.. there is a billion things that can go wrong in a r/c plane and more than once I had enough luck to find the problem before it happened. Hope this continues!
About the broken wire I think that it is not abrasion that caused this. There is a connector in the potentiometer board wich pulls the three wires real tight from a plastic support wich guides the wires away from the stick mechanism .. seems that this support crunched the yellow and red wire and after some up/down cycling of the throttle stick the wire suffered fatigue and started to break. This problem seems to happen with the aleiron if you are using mode I or rudder in case of a mode II transmitter.. I suppose that it didn´t happens so much with the elevator stick as it is often more around it´s center compared with the throttle stick, but even so it is worth checking it too. Carlos: this same thing happened to me with a old Futaba 8UHP radio, (and it costed me some helicopter parts, LOL) but I didn´t took it as a serious issue because it happened in a very, very used radio mostly with helicopters in wich I actually abused all the sticks with crazy movements. |
RE: A killer detail
I learned the hard way (several times, most recently my F-18 at Fresno Jet Rally in 2004) to check for full throw, proper direction, etc.. before start up and again before pulling the taxi tank.... looks like you dodged a bullet this time! Glad you found it before takeoff...;)
Barry |
RE: A killer detail
I can't help it....lol.....Futaba....[:'(] jk I know it could happen to any type.
RE: A killer detail
ORIGINAL: dbarrym I learned the hard way (several times, most recently my F-18 at Fresno Jet Rally in 2004) to check for full throw, proper direction, etc.. before start up and again before pulling the taxi tank.... looks like you dodged a bullet this time! Glad you found it before takeoff...;) Barry By the way, I just fixed the radio with some spare wire and shrink tube.. the problem was solved. The wires where donated from a JR servo , so I will not have any problem with this radio again! ;) |
| All times are GMT -8. The time now is 03:21 AM. |
