Jetcat Filters -
Hello all,
Working on installing my Titan SE and had a question regarding the IN and OUT ends for the jet cat filters (aluminum with basket and O ring). The instrctions state the O ring side is the IN end of the filter, but there are some schematics that show the filter with that end downstream. I just wanted to confirm this before I complete the plumbing. Thanks Dave |
RE: Jetcat Filters -
I always use the O ring side as the IN side of the filter.....i agree with you though that the instructions and schematics contradicting....
Richard |
DD |
If you set it as the "O" ring end as the OUT the dirt if there is any finishes up on the outside of the filter screen, making it easier to clean.
m |
ORIGINAL: mick15 If you set it as the "O" ring end as the OUT the dirt if there is any finishes up on the outside of the filter screen, making it easier to clean. The O-ring end should always be the IN side so fuel puts outward pressure on the filter basket. |
Makes good sense - thanks.
1 Attachment(s)
ORIGINAL: sc0tt The O-ring end should always be the IN side so fuel puts outward pressure on the filter basket. Sort of contradictory to what the manual states ...don't you think? However, I do agree the inlet should be on the o-ring side. |
1 Attachment(s)
ORIGINAL: Countryboy Sort of contradictory to what the manual states ...don't you think? However, I do agree the inlet should be on the o-ring side. |
ORIGINAL: sc0tt ORIGINAL: Countryboy Sort of contradictory to what the manual states ...don't you think? However, I do agree the inlet should be on the o-ring side. |
I agree. But even with the newer version, later in the manual there are 1-2 schematics where the filter figure appears reversed compared to the fuel schematic above.
This current maual clearly shows the fuel filter with the O ring towards the pump. I have some older installations where it was not that clear and I think one may actually be reversed but has flown that way for 4 years! Thanks for the clarification. Dave |
| All times are GMT -8. The time now is 08:40 AM. |
