Landing Lights
I purchased a King Cat that already had landing lights installed on the wings. They have two rows of five LEDs each.
There are two leads coming from each light bank, each lead has a JR male plug. One is labeled "Battery" and the other "Switch". The problem is there is no controller, switch or instructions as to how these are to be operated. The builder of the plane is unavailable for comment. Any ideas or help will be appreciated. Banker |
RE: Landing Lights
If it has retracts you could put a micro switch behind the strut so when it starts down the lights come on. To keep the whole thing from being hot hook the lead marked battery to the (-) negitive side and the positive the (NO) normaly open side of the micro switch, This way no channel is necessary.
RE: Landing Lights
Difficult to tell but battery is battery, and I guess you hook up the 'switch' to a mechanical switch which in turn can be activated by using a servo to manually move the mechanical switch from off to on. Its a guess only.
marc. |
RE: Landing Lights
Correction the connection to the micro-switch should be (NC) normally closed side of the switch!
RE: Landing Lights
1 Attachment(s)
Guys,
How about a servo input driven 2A relay swtich. Rob |
RE: Landing Lights
ORIGINAL: rorrock Guys, How about a servo input driven 2A relay swtich. Rob Who is the source for this unit? Todd Banker, Sounds like it might be the old JPOFL lights. Should be some sort of module to drive them. Can you take a pic of the lights themselves? Might help me identify what bulbs (therefore what voltage) Todd |
RE: Landing Lights
Todd,
I can provide them, they are made in partnership with a local electronics company.. The Specs Are Switching current: 2A Switching speed: 0.05~0.10 seconds (safety feature aspect - see below) Output connections: Common, N/O and N/C Size: 40x14x14mm (with heatshrink on). Weight: 13g Servo lead length: 300mm Input voltage : 4.0V to 7.2V SAFETY FEATURES Requires at least 5 good frames before comitting a switch to a different state If TX signal is lost, reverts to relay default setting (after ~0.5sec of constant loss) Relay outputs isolated from R/C circuitry Circuit is reverse-polarity protected Led to show if relay is active for troubleshooting. Rob |
RE: Landing Lights
1 Attachment(s)
Save a channel and it is cheap and pretty much foolproof!
http://www.alliedelec.com/Search/Pro...DESC=F4T7Y1-UL |
RE: Landing Lights
^^Great idea^^
RE: Landing Lights
I can do better than that, same thing, I have a dozen of these for various uses in my shop.
http://www.cnc4pc.com/Store/osc/prod...products_id=79 |
RE: Landing Lights
1 Attachment(s)
Here is a pic of the lights:
RE: Landing Lights
Do not need the roller, just a simple lever!
RE: Landing Lights
ORIGINAL: rorrock Todd, I can provide them, they are made in partnership with a local electronics company.. The Specs Are Switching current: 2A Switching speed: 0.05~0.10 seconds (safety feature aspect - see below) Output connections: Common, N/O and N/C Size: 40x14x14mm (with heatshrink on). Weight: 13g Servo lead length: 300mm Input voltage : 4.0V to 7.2V SAFETY FEATURES Requires at least 5 good frames before comitting a switch to a different state If TX signal is lost, reverts to relay default setting (after ~0.5sec of constant loss) Relay outputs isolated from R/C circuitry Circuit is reverse-polarity protected Led to show if relay is active for troubleshooting. Rob http://www.dimensionengineering.com/...PicoSwitch.jpg |
RE: Landing Lights
Alternately, make a home made Pico switch from just these parts:
#1 $7 servo #2 $3 relay If you wanna know exactly which relay to buy and how to hook it up, just PM me and I will explain in more detail. |
| All times are GMT -8. The time now is 05:48 AM. |
