RE: RCBEE Gear & Door Sequencer
What receiver are you using that will accept 22 V????
As the sequencer is designed to interface with the receiver I do not understand what you are trying to achieve. Typically you would have a voltage regulator connected to lower the voltage down to 6 or 4.8 VDC for connection to your receiver. |
O-My, I got all wrapped up in the voltages and forgot about that. Thanks for that, ***** getting old!!! :)
| All times are GMT -8. The time now is 10:59 PM. |
