turbine connection A4
Does anybody know if this aircraft is still in production, and if so has anybody had any building/flying experience with this particular airframe?
Regards Frankie |
Century Jets
G'day Frank,
Reference the A4. John Mauchline can produce a kit for a large A4 which I had originally seen flown by Manfred Bleck as a ducted fan. It flew well once up but was very marginal off the ground. I know that Brian Green bought it and fitted a turbine but I believe he lost it with a fire!! I am not sure of the size but my recollection is that it was about 1.5m long. If you give John a call I am sure he will be able to give you more information. Russell. |
A4
Hi
This jet builds fast and light. The only two modifications were to lengthen the top hatch by 3 inches to get to the turbine and lower the incidence on the stab by 1/8 in at the front edge. Retracts were made by Century Jets. http://www.rccanada.ca/bb/modules.ph...view_photo.php |
Thanks for the reply Russell. RC_MAN - have you flown the A4, and if so whats the performance like? More importantly, whats crosswind handling and ground handling like? And finally, how scale is it?
Regards Frank |
Almost forgot - nice result with the A4
Regards Frankie |
| All times are GMT -8. The time now is 06:27 AM. |
