Fuel Weight
Got to wondering how much fuel weight I carry on my Roo.
Looked up some weights on the internet. Kerosene: 4.822 lbs per gallon, 77.152 ozs. .603 lbs per pint, 9.648 ozs. 1.2055 lbs per quart, 19.288 ozs. For whatever it's worth. Pete Stapleton Simjet Rep |
Fuel weight
Wow, that's incredibly light for kerosene. Are you sure about that weight? Jet-A is usually figured at 6.7 lbs per gallon.
Fuel Weight
My "standard aviation maintenance handbook" lists the following:
JP-4 - 6.55 lb per gal JP-5 - 6.82 lb per gal kerosene - 6.84 lb per gal for what it's worth. |
Fuel wight
My Roo weighs 19.25# dry and 24.5# wet. 100oz tank with BVM UAT.
lighter fuel
Pete,
as a 30 year jet jock i'm pretty familiar with the weight of jet fuel. Jet A, B, or JP'4 all weigh about 6.7lbs/us gallon. Maybe you're thinking of lighter fluid. lol. |
Ya But
I have a 2 liter fuel take, how much does that weigh...lol ..metric, and the other...dang it's hard to keep it strait.
Andy |
Re: Fuel wight
Originally posted by grbaker My Roo weighs 19.25# dry and 24.5# wet. 100oz tank with BVM UAT. |
Fuel Weight
Gary, what turbine do you have on your ROO?
My came out to 16.5LBs. Dry with a RAM500. MB. |
Roo
I have a JetCat P120 on my Roo which is heavier than the Ram 500, but this plane was also repaired from a crash. I built a Composite Roo for someone else with an AMT Mercury and it also was near the 20# mark.
100 oz tank
1 Attachment(s)
The tank came from Plane Plus and is designed for the Roo. I believe it is built by Gary Mueller at Jet Tech.
Fuel Weight
&^%**^% thats a hell of a big tank in that roo !! how long are your flights ?? when i was flying my roo on a 1.08 and a pusher prop, i had 2 40oz tanks of glo fuel. I was landing after 20 min, and still had another 5 - 10 minutes worth left in there ... i use a 1.7 liter tank for jet a now and get about 6 min out of that ....
Wojtek |
| All times are GMT -8. The time now is 09:01 PM. |
