RE: Spool times....
quote: Behotec J66 and it is SLOW to spool, so slow that you need to decide on a go-around on the down wind leg. That is not a correct statement, in fact the 66 and all the Behotec engines can have their acceleration and deceleration times adjusted in 4 different ramps. The 165 and 180 are set to 3.7s and the 66 can be set to 2.8s If the engine is not spooling up that fast then it has to be investigated and repaired if necessary. I encourage you to return it for an inspection. regards Peter Here are the facts, the engine is slow to spool. I have timed it several times while observing the RPM's on the monitoring unit and on average it is about 8 seconds to reach max RPM from idle. This has been done on hot days as well as cold.... I have attempted to adjust the ramp times and every time I move away from the stock setting, no matter how small the movement is, the engine over temps on spool or flames out completely. I have no doubt that it most likely needs service to some degree based on the number of hours I have on it but honestly it has Always been slow to spool. Now, with that being said, this engine is totally reliable. It starts every time with so much ease that it is mindless. I makes excellent power and never gives me one bit of trouble. The only thing I have to deal with is making sure I make any decision that requires power early and execute that decision with a cushion of time to spare. Please don't take this as me bashing the J66, just the oposite...but spool times are what they are....I look forward to getting them improved. Peter, I will get it up to you at some point for inspection, I just have to make the time and effort to get it done. |
RE: Spool times....
ORIGINAL: Pete737 ..............When you say the newer P-80's or P-70's spool faster, Do you mean the most recent ECU version? Or is it a physical issue like CC design? How can you tell? |
RE: Spool times....
got the above mentioned P-70 back today, it now has an updated ECU (both hardware and software) to 6.0q. the spool time is still just a tad over 7 seconds from idle to 123K.
RE: Spool times....
ORIGINAL: KC36330 got the above mentioned P-70 back today, it now has an updated ECU (both hardware and software) to 6.0q. the spool time is still just a tad over 7 seconds from idle to 123K. Pete |
RE: Spool times....
i have no idea, both accelerations are set to FAST in the menu.
RE: Spool times....
Does anyone know of a definitive list of spool times, is it featured in the comparison table at the back or RCJI mag?
I would happily substitute thrust for a better spool time, the joys of small field flying! |
RE: Spool times....
ORIGINAL: J.F Does anyone know of a definitive list of spool times, is it featured in the comparison table at the back or RCJI mag? I would happily substitute thrust for a better spool time, the joys of small field flying! Pete |
RE: Spool times....
ORIGINAL: J.F ...............I would happily substitute thrust for a better spool time, the joys of small field flying! |
RE: Spool times....
ORIGINAL: SJN again...it also depends on which generation the turbine is. My simjet 3000SP accalereates quite slow. But it is also a few years old now. no problem change the pump to a Hausl 30020SP change the battery to a lipo 2s1p 7,4 set acc to 008 deac to 005 and done! |
RE: Spool times....
ORIGINAL: Pete737 ORIGINAL: KC36330 got the above mentioned P-70 back today, it now has an updated ECU (both hardware and software) to 6.0q. the spool time is still just a tad over 7 seconds from idle to 123K. Pete Mike |
RE: Spool times....
ORIGINAL: BaldEagel I assume its a bit like chipping your turbo car, the tweak to the software/hardware just improves the reaction time, its also a bit like the 0 - 60 time on your car all a bit pointless except for bar talk, its the mid range acceleration that counts, i.e. don't close the throttle all the way, only close it too one third throttle whilst flying around, this was recommeded to me from Ali, and I think he knows what he is talking about. Mike If i know that i can punch from idle on late approach to full power in 2.5secs rather than 6 secs because of the turbine i bought, that makes life much easier for landing. Plus, with more choice and fewer differences between manufacturers now, it might be the next consumer benefit, I would substitute kero start for faster spool times, and look at the effort that has taken for some companies to get right.. |
| All times are GMT -8. The time now is 09:25 PM. |
