Servo extensions?
I ordered some male & female Futaba plugs from Servo & Stuff, & the male plugs were garbage. For you guys that make your own extensions, where do you get your supplies?
Thanks |
RE: Servo extensions?
Dreamworks is a good source
get mine from hobby city make sure you have good crimper
I buy my stuff here www.cheapyharnesses.com. As for crimping tool, get a good one from Radio Shack or Fry's. I have the $10 one from these guys and it also works great. I also use a wire stripper from Radio Shack, which is a POS if you ask me.
Once you start naking your harnesses, you'll never go back. David |
ORIGINAL: Brickyard I ordered some male & female Futaba plugs from Servo & Stuff, & the male plugs were garbage. For you guys that make your own extensions, where do you get your supplies? Thanks http://www.hansenhobbies.com/ |
ORIGINAL: Brickyard I ordered some male & female Futaba plugs from Servo & Stuff, & the male plugs were garbage. For you guys that make your own extensions, where do you get your supplies? Thanks I have tried all the others, including Hansen Hobbies, and the Peak stuff is superior. It is exactly what you get if you order JR heavy duty pre-made extensions. |
Thanks guys.. FYI, the male plugs from Servos & Stuff dont hold in the stock Futaba, or the female plugs from Servo's & stuff. They just fall right out like they're too small. Not sure if I have a Bad batch, but I wont be ordering from that place again.
| All times are GMT -8. The time now is 01:17 PM. |
