Show me your engine test stand
I just wondered how people are test running their engines whilst out of the model. I would want to be able to measure the thrust whilst doing so.
RE: Show me your engine test stand
good idea! Im building a stand too. this thread would really help!
Pete |
1 Attachment(s)
This is what I made for all my engines. Any size nitro beam mount, radial mount gas engines and turbines. I have other mounting plates for the nitro and gas engines. The two sliding plates are 3/8" cold rolled steel. I use a 50 lb.fish scale to check the thrust. The legs come off so you can take it to the flying field to run up your engines.
Cancelled
1 Attachment(s)
Here is my P120 on the bench.
do you have yto use a UAT with a test rig setup? whats the usual tank config for running on the bench?
Pete |
ORIGINAL: Pete737 do you have yto use a UAT with a test rig setup? whats the usual tank config for running on the bench? Pete not at all, the only fuel system i use for bench running is i hook my start up/taxi tank directly to the fuel pump. i can't help but notice in all the above posted pics none have a FOD guard, myself i won't run a turbine at all (on the bench or in a jet) without one. |
ORIGINAL: KC36330 ORIGINAL: Pete737 do you have yto use a UAT with a test rig setup? whats the usual tank config for running on the bench? Pete not at all, the only fuel system i use for bench running is i hook my start up/taxi tank directly to the fuel pump. i can't help but notice in all the above posted pics none have a FOD guard, myself i won't run a turbine at all (on the bench or in a jet) without one. |
1 Attachment(s)
Here's mine. Altecare sells them.
Nice, but $275? [X(]
I see no reason what so ever to have a test stand unless its some type of home built where you are tweaking and wrenching after each run. Running a P-120 on a test stand is a waste of good air time imo.
V.. |
1 Attachment(s)
Here is the one I used to test run my Wrenn SS as it was my first turbine I thought it might be a good idea to learn about turbines on the bench. A little agricultural but I thought it was sufficiently strong to contain the beast.
The most memorable moment occured when on the second run when I advanced the throttle towards full power AND the turbine moved. After bending the throttle stick on the slow down I found that it had moved in the holding straps. This was cured by lining the straps with wet and dry sandpaper. |
ORIGINAL: Vincent I see no reason what so ever to have a test stand unless its some type of home built where you are tweaking and wrenching after each run. Running a P-120 on a test stand is a waste of good air time imo. V.. i somewhat agree with you Vin that's why my test board is a 2' x 3' piece of melamine with two short 2x4s screwed to one end for strapping the turbine to, i only use it to test runs when i suspect a problem and it's easier to pull the turbine/ECU and run it on the bench them start pulling all the systems out of the jet to find a possible problem. i also strapped my Titan SE down to it for a short run when i got it second hand before installing it into a new jet. no way in the world I'd pay for one and i see no need for all the fancy bells and whistles that some boards I've seen have on them. |
Bolt it on and fly it.;)
1 Attachment(s)
For the first turbine it's a good idea to lay everything out on the bench and run it before installing in a plane. Then you can figure out where everything goes in the plane knowing that it's right. And of course for the tinkerers and homebuilders like Jeff it's an absolute must.
Here's a pic of my sophisticated set-up... |
1 Attachment(s)
Here's a test stand for you!
Made in Greece!!! |
1 Attachment(s)
Hello,
Here is my favorite test stand used for my P80 and Wren 160. Before fitting your turbine in a plane, you can easily learn how it runs and also test the kerosene feeding system. Regards, Alain |
Ok, What size tank would you guys recommend? Im gonna have to grab one from my LHS before I run my engine.
Can I use any filter for my fuel? Maybe a gas or diesel filter? Anyone make a FOD screen for the Falcon? I don't think Ill have a problem fitting one up but how do you attach it? I see some bolts that I could use but I don't really want to touch them unless I am sure what they are for. Thanks, Pete |
ORIGINAL: Pete737 Ok, What size tank would you guys recommend? as far as the filter, there should be one included with your turbine. on my refueling jug i use an inline fuel filter from the auto parts place. |
1 Attachment(s)
This is my test stand from ''Altrcare R/C''
Kilroy Richardson |
1 Attachment(s)
Here is my stand had this made back when I had a hobby shop so we could demo our turbines and when we worked on them
1 Attachment(s)
Here's mine, made it to test run my Wren, engine and test rig both sold now
1 Attachment(s)
Hey guys, Does this look ok for the stand? I have not made an accesories tray yet.
Thanks, Peter |
ORIGINAL: ntka_1974 Here's a test stand for you! Made in Greece!!! |
| All times are GMT -8. The time now is 01:38 AM. |
