HELP F-15 Elev neutral position
1 Attachment(s)
Hi,
I need help to find the elevator neutral position on Xtreme Jets F-15. I don't know how to make this. Thanks Fabio |
RE: HELP F-15 Elev neutral position
Ola Fabio, presuming that this is the same "shape" of the Skymaster, Jetlegend, etc.. and this is the case in my opinion, the trailing edge of the stab aligns with the extreme point of the fuselage. From this point, the elevator throw movement should be 5cm up and down.
Um abraço, Enrique. |
ORIGINAL: erbroens Ola Fabio, presuming that this is the same "shape" of the Skymaster, Jetlegend, etc.. and this is the case in my opinion, the trailing edge of the stab aligns with the extreme point of the fuselage. From this point, the elevator throw movement should be 5cm up and down. Um abraço, Enrique. Hi Enrique, How are you? Ok... but I still have a doubt about your information. When aligns the stab with extreme point, I can see the stab a little UP in comparasion with the wings. I think the incidence wings and stab is 0(zero)... or no? I sent e-mail to Anton but a guy called Jonh reply me without details about this.... no satisfatory answer. Thanks Fabio |
Yes, the stabs look a little like "up" trimmed in relation to the wing root, but this is normal.. tonight I will take a pic of mine in a sideview and post it here, just for you have a better reference.
at+,Enrique |
ORIGINAL: erbroens Yes, the stabs look a little like "up" trimmed in relation to the wing root, but this is normal.. tonight I will take a pic of mine in a sideview and post it here, just for you have a better reference. at+,Enrique Ok Enrique!! Muito obrigado! Abraço |
1 Attachment(s)
as promised:
at+,Enrique |
ORIGINAL: erbroens as promised: at+,Enrique Hi Enrique, Thanks for pics! I go to make this in my F-15! Good luck for me! hehehe Nice your bird! Regards Fabio |
1 Attachment(s)
Enrique, I'm still need to confirm the correct neutral position in my F-15. Can you help me again? Please see the pics and let me know some conclusion! Thanks </p> |
You are fine, and don´t worry about the pitch trim, as the elevator response on the F-15 is very soft and nice.
Presuming your CGis about on the right spot ( indicated by the manual) this stab position will make you fly straight and level at cruising speed. Of course, right after takeoff you will need to hold a little "up"stick until the speed builds up... meanwhile you may concentrate in triming the aleirons wich are must faster in response than the elevators. Aspotter may be helpful for doing this at the maiden flight. Good luck with the maiden, and if possible send us a video so Juninho can enjoy it too! :-) |
Enrique,
Please.. let me know your control throws setup. Elevator___ mm Aile ___mm Rudder___mm Flap ___mm or degree Sorry for many questions. The video is OK. Abraços e obrigado. Fábio |
No problem, and as your F-15 (unlike mine) has aleirons and flaps you should use this settings:
http://www.skymasterjet.com/image3/64.jpg Obs: In my airplane Iuse 25%de-sensitizing exponential rate on both roll and pitch axis. also worth to mention that the F-15 is one of the few jets that don´t need flaps or a speed brake to slow down and land decently. Abraço, Enrique. |
Why haven't you checked all of this with an incidence meter???....Sure would take some of the guesswork out of all of this...
Kevin |
the problem with the incidence meter is that you have to guess anyway a reference to work with...http://www.rcuniverse.com/forum/js/f.../msn/50_50.gif
1 Attachment(s)
I usualy use this low tech solution.....works great :D
Yep, The simplest things sometimes will work well. Never underestimate the power of a quicky Digital sapshot to use as a diagostic tool. Use to have to get them developed. Now just takem and weep.
ORIGINAL: SJN I usualy use this low tech solution.....works great :D |
ORIGINAL: erbroens the problem with the incidence meter is that you have to guess anyway a reference to work with...http://www.rcuniverse.com/forum/js/f.../msn/50_50.gif Kevin |
Sincerely I think that is not simple as that, but I really don´t want to disagree... You may be right!
ORIGINAL: erbroens Sincerely I think that is not simple as that, but I really don´t want to disagree... You may be right! Kevin PS...And trust me...If I were wrong there would be fifty guys jump on here and tell me so!!!.....http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif..... |
| All times are GMT -8. The time now is 05:40 AM. |
