RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Skymaster Oleos/Oil Help (https://www.rcuniverse.com/forum/rc-jets-120/8686177-skymaster-oleos-oil-help.html)
schroedm 04-16-2009 03:43 AM
Guys,
Noticed that one of my ViperJet oleos has leaked its oil so I was about to fix it. However, the oil supplied is really thick to the point that it cannot even be sucked up into the syringe. Is this normal? Do I need to 'thin' it with anything? Can I use anything else?
Rgds,
Mark
digitech 04-16-2009 03:56 AM
RE: Skymaster Oleos/Oil Help
ORIGINAL: schroedm
Guys,
Rgds,
Mark
you need RC car schock absorber oil , they come in different thickness.
schroedm 04-16-2009 04:02 AM
Sandor,
Any guess as to which thickness? i.e thin, medium, thick?
Mark
digitech 04-16-2009 04:39 AM
ORIGINAL: schroedm
Sandor,
Mark
somewhere around medium as i can remember , i just looked i had some left from a MB-339.
just buy thin medium and thick.
try what is for the best?
3DHELINUT 04-18-2009 11:46 PM
I replaced the silicon lube in my SM F-86 struts with some OFNA 5000wt silicon differential lube. this worked out great and now the plane sits with the struts 1/2 compressed. on landings she justs sticks to the round and does not bounce.
Alan
Vincent 04-19-2009 09:44 AM
Team Losi 3000 differential oil is what used on my SM F-86
V..
schroedm 04-19-2009 11:11 AM
I went with 3000 weight oil in the end - seems to have done the trick.
Rgds,
Mark
CARS II 04-19-2009 02:41 PM
1 Attachment(s)
I use # 25 weigt from cars shocks ( I just noticed "cars" funny :D ) to lube the O rings inside the retracts, it makes them very smooth and you get less friction on the cylces ( more cycles per tank ) [&:] [8D]
:D :D
chrigui 04-20-2009 06:55 AM
ciao Vinc
how many cm3????
Vincent 04-20-2009 07:07 AM
Chris,
I just counted how many drops i put into the strut and tried the travel each time. Did the same for the other one.
V..
chrigui 04-20-2009 09:46 AM
ok...
