RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Tamjets Pull Pull steering (https://www.rcuniverse.com/forum/rc-jets-120/8813119-tamjets-pull-pull-steering.html)
iiievolution 05-31-2009 05:56 AM
1 Attachment(s)
Hello
What are the small green springs used for in the tamjets pull n pull steering kit?
Paul
Mace 05-31-2009 06:25 AM
RE: Tamjets Pull Pull steering
I believe they are guides for the cables to run through if need be. Correct me if I'm wrong.
MACE
KC36330 05-31-2009 07:02 AM
they keep the cable from twisting and fowling around the servo arm in the retracted position when they go slack and it's turing with rudder input.
iiievolution 05-31-2009 09:28 AM
Ok thanks, I thought thats what they were for, but how are they installed?</p>
Paul</p>
</p>
iiievolution 05-31-2009 09:48 AM
1 Attachment(s)
In my previous post I mean how is the sequence of items installed. Please look at the picture. Its expanded and not tightened up yet on the picture. This is going to be the nose strut side, not the sevrvo side. Is this correct?
Paul</p>
seflyer 05-31-2009 09:51 AM
on my 16 they were not used or shown in the manual. I used a ziptie as shown and it takes care of the cables when slack.
Kevin
Kriptonic69 05-31-2009 07:30 PM
I belive that is a Tamglish part. Ment to fool everyone.....</p>
I hope Tam chimes in with their use.</p>
Gene</p>
ianober 05-31-2009 09:02 PM
At point I used them to keep the cables separated and out of the way when the gear was retracted. They are not springs so they hold their shape when stretched out.
iiievolution 06-05-2009 10:11 AM
1 Attachment(s)
Hello
Ok I received an email from Tam. The green springs are there so that you can fix your rubber band or your tie-wraps that keep the cables clear of the strut when retracted. When the gear is down the cables move freely within the green springs. Look at the picture.
So now, as we say, we have heard it from the horses mouth. Thanks Tam and to everyone who has answered here with their ideas.
Paul
