123 battery setup
HI all, how many of us are using 123 batteries in our jets, with no regulators( 7.2+ , off the charger and leveling off to 6.5volts for hours), with, say two JR 331 servos and the rest digital. Any negative effect on the non digital servos.
Thanks Rcpete |
RE: 123 battery setup
Pete
Using two 2 cell A123's through two Fromeco Kodiak switches, these do not regulate the voltage, but give a Mah reading of the used power, I have eight digitals and one analog servo with no detramentle effects noticed so far after 30 flights using them. Mike EDIT: additional information, Rx FASST FS6014, servo's all Hitec. |
Pete,
Nope none at all. I use the 331 for the retract/brake servo and all is fine. I'd say I have 15-20 flights so far this year using a 2 cell A123 (2300Mah) RX pack. AR9000 RX. The 6 other servosare the 3421 digitals. Dave Rigotti |
Dave, I just bought four 3421's for my JL CT-114. have you had good luck with your's? Any prob's? TNX Hooker
Hi Pete,
I have 2 JR351 servos, wheel brakes and gear valve. No problems with the brake servo but the gear servo does not move full range at times and also will buzz and act as if it's stalled but it will be in mid throw. I put a spare regulator in line temporarily and that solved the problem. Joe Rafalowski put me onto the digital version, I believe they are JR 831. Same size and they will solve the problem. I'm using a 2300mah A123 with Futaba 6014FS. Hope to see you at Liberty Bell. Mike ORIGINAL: rcpete347 HI all, how many of us are using 123 batteries in our jets, with no regulators( 7.2+ , off the charger and leveling off to 6.5volts for hours), with, say two JR 331 servos and the rest digital. Any negative effect on the non digital servos. Thanks Rcpete |
Hooker,
I have run 3421`s in several jets with 123 batts on straight voltage. No problems with them. V.. |
| All times are GMT -8. The time now is 06:16 AM. |
