FALCON 120
1 Attachment(s)
PICS hereare the mods i made to make this plane safe for a p-80.6 new ply ribs.reglue everything.rehinge ,sheet open bays.new wing weight is2 pounds.old one ,no gear 1 pound
RE: FALCON 120
Good looking build, and...
thanks, from all of us, for not typing in all caps. So much more pleasant to read. More pics please. Paul |
RE: FALCON 120
cool
RE: FALCON 120
Very nice work. I have over 30 flights on mine. Great flying Jet. It is slower than most because of the flat bottom air foil. But they fly Great.
RE: FALCON 120
I still have mine sitting in pieces. Looks like this will be my winter rebuild. I plan to re-enforce and glass the wings and do a new paint scheme for the whole plane. Not sure of the engine choice yet. Originally it was going to be a Rabbit, but that is going straight into my F-16 I'm currently (not) working on.
RE: FALCON 120
thanks to all.. what is the average weight with the larger turbines?? im glassing and painting this big slug...the wing inside was scarery!! no glue anywere..
RE: FALCON 120
1 Attachment(s)
i found a place for 24 oz of fuel.. stock fuel tanks,no fab..fuel tank sticks out 3/4 of inch. now will go into fuse.can connect lines from rear hatch.
RE: FALCON 120
Great work! Nice model.
Thanks for the photos and info. I'm learning. Actually moving to Jupiter this year. Keep educatiing I need it! Thanks, Charles |
RE: FALCON 120
1 Attachment(s)
see if you like this idea.. closedup top alerion gap. cant see pin hinges. pin is removed for painting.replaced with one long pin.1/16th..no grove to cut.. cant see them when deflected. 1/64 ply glued to hing slots. then ca, and pined. ply wont splt like balsa grain does..used triangle stock on top of wing so it filled the gap and matched hinge thickness..</p> |
RE: FALCON 120
Great!
But I don't understand. Guess I'll just have to send you my wings and stab. [sm=bananahead.gif] From where or how do you get the pin in? Photo? Don't you have to align all hinges with the pin in before gluing? Address so I can send you that stuff. [sm=biggrin.gif] Charles CASA C-101 brother, #1 |
RE: FALCON 120
you use one long pin ,from the end .
RE: FALCON 120
1 Attachment(s)
nose gear ,fuel tank
| All times are GMT -8. The time now is 08:21 AM. |
