RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   EVSD-5U-PRO Multi-Function Valve help (https://www.rcuniverse.com/forum/rc-jets-120/8874203-evsd-5u-pro-multi-function-valve-help.html)
InboundLZ 06-23-2009 12:04 PM
GUYS, need your help!
I have the EVSD-5U-PRO Multi-Function Valve installed in my MB339...and after some tinkering I have it working properly with one exception, and I dont know how to fix this issue.
The valve, by design, will always failsafe to the gear down position when you boot up the system regardless of where you have your gear switch.
This is to prevent acidental retraction of the gear if you boot with the switch in the wrong place. Nifty right? Not so much...
Here is the issue, if your gear is up and doors are stowed (like it would be when you assemble it at the field) and you service the air, when you boot the RX the gear is coming down NOW! The problem with that is the system does not bother to open the doors first. THIS IS A SERIOUS PROBLEM as it like to rip the doors right off your plane.
Would anyone out there have any idea on how to either get the system to open the doors first or how to disable the gear down on boot failsafe all together?
Any and all ideas welcome!
Thanks!
*******UPDATE*******
A "friend" made it clear to me that I failed to give one very important detail on this set-up. I am using the Valve in MODE 2. I believe everyone was assuming I was in MODE 1, and I assumed you understood I was MODE 2.
<br type="_moz" /><br type="_moz" />
InboundLZ 06-23-2009 01:58 PM
RE: EVSD-5U-PRO Multi-Function Valve help
Anyone?
Aero65 06-23-2009 01:59 PM
Hi
I know that this is not really a solution but this is what we do with our 5U installs.
1. After flying we dissconnect both tanks to drain all pressure as called for by the directions to help the life of the digital pressure sensors.
[Next time we fly]
2. Assemble plane at field.
3. Fill air and use manual button to put gear down. TX off doors will cycle with manual button.
4. Prep fuel air and fly.
digitech 06-23-2009 02:03 PM
[quote]ORIGINAL: F-18DiamondBack102
Thanks!
<br type=
weird i have the same one and dont have this problem.
you sure it works the right direction?
can you use the brakes when retracted?(not disabled by RX)
the evu-pro does this itself..
also make sure if you use spektrum you rebind after you are done.
(my gear comes down when i switch it on without the TX BUT it opens the doors first.
i think you have the valves and doors reversed on the unit.
firtst you need to set those right THEN program the unit.
InboundLZ 06-23-2009 02:04 PM
Hmmmm, I see what you are saying....
Question: As the system is up without the TX does the Valve still try to drive the gear down or does it do nothing?
If what you are saying works that is a perfect solution.....
Thanks!
Anyone else have ideas?
InboundLZ 06-23-2009 02:09 PM
Sandor....
You might have something there....
The diagram in the book is 180 out...I set my system with the airlines as per the drawing and I was having a hell of a time getting the brakes to work. They would work with gear up but not gear down. I reversed the physical lines and now the brakes work properly. Perhaps i need to do the same with the door lines??? Can I reverse the valve sequence on the unit itself?
So, just so i am clear, when you have your gear up and doors closed and you boot the system it will automatically put the gear down but it opens the doors first? And if that is true if you boot the system with the gear already down you will still have the doors cycle anyway?
Sorry if my questions are stupid....I have been up way to late trying to get this bird finished!
digitech 06-23-2009 02:41 PM
Sandor....
there are no stupid questions..
if you had your brakes working only in the up position it is a problem of reversing all airlines.
then program the pro valve with the reverse function inside.
i believe the manual shows you the correct sequense to connect all airlines.
the unit was developed also to NOT retract when switching on.
but this only works if you tell your failsafe to have gear down in failsafe situation (at least this is what i do)
i build my model up on the field , pressurerise the system then switch the rx on and the gears come out.
ps : make sure your airsupply is OVER the min failsafe!! otherwise you will get a gear down ! could be a weird error when setting up your model!
also do not forget put the door valve on the same supply as the gear otherwise if you have no more brake air and your doors are on that system.
the failsafe will lower the gear it wont care about your precious doors ;-)...
furloughed ual 06-24-2009 12:26 AM
as I understand this valve, there is no provision to slow the gear and door speed other than using restrictors in the airlines......is this correct?
InboundLZ 06-24-2009 12:38 AM
OK, something is not right, something is bad wrong.
I disconnected my door rams so I would stop beating the crap out of my doors....
This is what I have:
(Starting with the gear down and air pressure above the minimum fail-safe level of 50 PSI)
Gear switch in down position,Gear down, doors closed, brake system working....everything is normal.
Gear switch in up position, doors open, gear up, doors close, brake system disabled, again everything normal.
Now, I shut off the radio system....system purges any air pressure....normal.
I turn on TX, then RX (gear switch in down or up position as it makes no difference) and the gear deploy instantly however the doors stay closed.....BIG PROBLEM!
I have tried it in every way possible and I can NOT get the system to open the doors before the gear is deployed. PERIOD. Makes no diff if i turn on the RX only and try to cycle the doors with the manual button, AS SOON AS POWER IS ON THE SYSTEM THE GEAR COMES DOWN. NO EXCEPTION!!!!
An interesting note that if I try the same experiment in mode 1 the doors open and the gear comes out at the same time.
This VALVE is unusable for mode 2 with this condition, what am I doing wrong?
InboundLZ 06-24-2009 12:43 AM
Correct, they supply you with a festo type regulator valve and several in-line restrictors...you can use either or. I used the inline ones and they work fine.
digitech 06-24-2009 01:46 AM
Reverse the 2 air lines that go to the gear.
then in the setup up from the valve reverse that valve , that should do the trick.
if not it looks like a bad valve..
or i am missing something.
InboundLZ 06-24-2009 02:09 AM
I did that, no joy.
Chad at Sin City has the same valve in his BARF and it does the same thing. He has to run in mode 1 and keep the nose door open all the time, he would like to used mode two and clean that door up but he has the same problem I do. I do find it interesting that in mode 1 with the gear up and the doors closed if you power up the system it blows the doors open and the gear down at the same time, but in mode 2 it holds the doors shut.
Now chad advised me to let this "leaf in the trail" go and move on to something else but I had to keep thinking about it. This is only a problem on the first deployment of the day. Once the gear is down and the doors in the right place everything is normal. I have a solution, although for 470 bucks I should not have to come up with a solution, but what if you did this....
You get to the field, you assemble your jet, air tanks are empty (because you purged them as per instructions after last flying session, right?). Now you have everything hooked up and you boot the system, nothing happens because you have no air in the system....This is where my solution comes in. The goal is to open the doors and extend the gear, right? Right! Well, I figure you could put a fill valve in line with the door down line and the gear down line. This way you could blow the doors open with you air supply (compressor) and then blow down the gear. Presto! Gear is out and doors are not tweaked. Now you can fill your air tanks and get on with your day, Just always remember to shut down the system with the gear down.
At the end of the day you put the gear up and turn off system, disconnect airlines and purge the air tanks and you are ready for the next flying session!
So, a couple of quick steps and we have the problem solved. I might just shoot a video and post it so you see what I mean...
What do you think?
And Sandor...how would I know if my valve is toast??
George 06-24-2009 03:43 AM
Double post.
George 06-24-2009 03:46 AM
Like Chad, I have it in my BARF and I'm using mode 2 (close nose door with gear down), and my valve does the same thing in Mode 2. I have not been around and had the chance to play with it yet to see if I can fix it. Since I only have the one door, I just opened the door before powering up. I agree, you shouldn't have to do something strange for it to work like you want. I'm sure Air Power can change the software to fix this easily. BTW, I have one of the very first production models, so maybe it is matter of when we got them. I know for sure, some programming was changed AFTER mine because of some irregularities in the programming that I found.
How old are the ones in question, F-18, Chad, Sandor?
Sandor,
Are you using mode 1 or 2? If mode 1, then that explains the difference, if mode 2, then we have problems.
R/
George
digitech 06-24-2009 05:16 AM
ORIGINAL: George
Sandor,
R/
George
i am indeed in Mode 1
i just emaild airpower and this link to investigate what is going on..
have asked also about 1 gent and 2gen versions
SinCityJets 06-24-2009 09:36 AM
George,
Ours are about three weeks old from Todd. Mode 1, it works fine, mode 2, like Dave said, it wants to held the doors shut and blow the gear open. Bad combination. I agree with you George, this is something that should be able to be updated through software, or maybe we're all just idiots and it is a simple programming feature. (The latter is certainly possible on this end).
Great valve, but this little quirk can be annoying, especially on a plane like the 339 where the doors really need to shut after the gear is down.
Chad
George 06-24-2009 09:58 AM
Three weeks? Well, so much for that theory.
Hopefully AP has checked this thread out and will let us know something. I know Todd is on vacation right now, but he'll see this when he gets back and he may have some insight.
George
InboundLZ 06-24-2009 11:55 AM
1 Attachment(s)
What sucks for me is I am out of time, this bird has to go into a trailer (which is yet to be set up to haul jets) this weekend and I have NO time to waste. I am going to have to use my fix as mentioned above.
Very disappointed that this valve gets the to the 99 yard line only to drop the ball and not score....I am sure a S/W update will fix it but it is going to be a major PITA to remove from the jet to install and the turn around times just add to the bad JUJU....
Here is few pictures of it installed....
GR7Racer 06-24-2009 01:23 PM
How about a manual on/off valve installed on the gear down pressure line? With the valve closed, you can assemble the plane, pressurize the system, turn on the radio, insure gear doors are open before opening the valve and dropping the gear. Then just leave the valve open for flying. I've seen a similar fix for the airplanes with this valve and retracts that need pressure to keep the gear down and locked. When you power down the system the pressure is released and the gear becomes unlocked and the airplane ends up on its belly, so a valve is installed that you shut off before powering down the system that holds the pressure.
KennyMac
InboundLZ 06-24-2009 01:48 PM
Kenny, I like that even BETTER!
You are thinking for sure!
Aero65 06-24-2009 02:47 PM
Hi
Did not realize that your in mode 2, all my birds are on Mode 1. I will try to get a message to Airpower too and see what they are working on.
BTW nice install really neat and well laid out, Good job sir!!!
InboundLZ 06-24-2009 04:18 PM
Hopefully one of you guys will make some kind of contact with AP and they will have a solution....
Thanks for the kind words, you can see more of the build here: http://www.rcuniverse.com/forum/fb.asp?m=8877866
InboundLZ 06-25-2009 01:41 PM
OK, I added two fill valves in-line with the gear and the door down lines....
Proceedure:
Asemble aircraft
Using air pump blow open doors
Using air pump blow down gear
Manually push doors closed
Pressurize Air system
Proceed as normal...
Not an elegant solution but it works and my doors are not getting crunched.....
SinCityJets 06-25-2009 02:13 PM
That's a pain in the butt, and needs to be fixed on the unit itself.
Chad
InboundLZ 06-25-2009 04:12 PM
Yeah, but RIPPING your doors off is a BIGGER pain in the butt....
One has to wonder how this ever passed operational checks?????
Airpower RC 06-25-2009 11:04 PM
Dear Sir,
I am sorry, cause your puzzlement!
I hope at first that you can check several things
1. Please confirm that each valve export the air normally (V1~V5).
*First of all, please input the pressure in 120 PSI range , and confirm that screen " GSF " stops blinking pattern.
2. Please confirm that your air line connect all devices to arrange correctly.
V1-(Gear out) / V2-(Gear in) / V3-(Door open) / V4-(Door close).
3. Please check your equipment, " Gear & Door Air Cylinder " leaks the air.
*Abnormal gear or door device , will influence normal movements of the valve.
4. Please notice the valve surface light change V1~V4. (in mode 2)
*(mode 2) The normal change light is as follows :
On power → V2-(Gear in) & V4-(Door close).
Press " MANU" button → V4 Jump V3-(Door open) → V2 Jump V1-(Gear out) → V3 Jump V4-(Door close)
5. Reverse your gear & door valve at the same time, can keep gear out in no power.
PS. My English not fine, I am sorry !
Dirk
SinCityJets 06-25-2009 11:35 PM
Dirk,
Just to clarify what is happening, here is the simple version:
We store the planes with the gear retracted.
When we turn the plane's receiver ON, the gear wants to extend, which is normal.
In Mode 1, there is no problem, the valve opens the gear AND Doors.
In Mode 2, there is a problem. The gear wants to open, however the DOORS are held shut. This is a problem because the gear could break the doors, while trying to extend.
Chad
digitech 06-26-2009 01:15 AM
ORIGINAL: SinCityJets
Dirk,
Chad
Dirk means have you checked this?
InboundLZ 06-26-2009 02:46 AM
I can assure you mine does not do that^^^^^
On power up V1 and V4 are illuminated. Another words, Gear DOWN door CLOSE...AT THE SAME TIME....
Airpower RC 06-26-2009 04:01 AM
[quote]Dirk means have you checked this?
Press
Dear Sir,
Your plane does not fly , while collecting, do you keep gear in or out ?
Thank you !
Dirk
CraigG 06-26-2009 06:01 AM
Dirk suggested to: "First of all, please input the pressure in 120 PSI range"
The digital pressure readouts on my EVSD are about 25 psi less than what my pump guage says. I have used my pump with mini guages and never noticed this wide a psi spread so I figured my pump was reasonably accurate. Anybody else notice this?
I'm a little hesitant to pump up the unit to 120 psi.
Craig
digitech 06-26-2009 06:31 AM
Press
that would mean you have the V1 reversed and the airlines connected incorrect?
InboundLZ 06-26-2009 12:02 PM
Press
Arrrrrrrrrrrrrggggggggggggg!
My valves and lines are connected correctly, period. The system works perfectly in every way EXCEPT upon system power up. I am going to have to shoot a video because words are not getting it done.
This valve is has a serious design flaw or the ones Chad and I have just happen to be broke in the same exact way.
InboundLZ 06-26-2009 12:06 PM
1 Attachment(s)
Craig
Craig, I noticed the same thing. I have the analog gauges installed as well and when I am servicing the system my compressor and the analog gauges agree, the Digital gauge reads 20-25 pounds low....
Silent Lamb 06-26-2009 12:35 PM
Have you tried binding the system with your retract swicth in the "other" position. Give it a try?
InboundLZ 06-26-2009 12:44 PM
I have tried it in every possible way. Bound it with gear up, and gear down....
It makes no difference. I have even crossed the up and down lines on the gear. That keeps the gear up on boot up but the brakes done work on extension and the GSF fails the gear to the UP position.
The S/W on this valve is hosed up, period. There is not a mechanical fix for this.
Silent Lamb 06-26-2009 12:56 PM
Bummer[:@] Sorry, I am out of ideas then[:o]
InboundLZ 06-27-2009 01:39 AM
Ok, Made a quick video of the valve in operation, this should clearly show the problem I am having.....
[youtube]http://www.youtube.com/watch?v=mSYQMxCw82c[/youtube]
digitech 06-27-2009 02:41 AM
Great video
i am taking my hawk out today for a spin
since my doors can also be opened or closed with or without the gear up or down
i will try also today in mode 2
be advised i am using now the latest Sequenser pro with Failsafe
basicly same unit but with external valves..
so the software should be the same.
lets get this cleared..
George 06-30-2009 07:16 AM
Has there been any resolution yet?
