Help with translation
A customer has written me the following, seems I am unable to translate this to english... can anyone tell me what he is asking?
guero saber o presso das pessas avulssas da turbina de helicoptero a parte de dentro eixo compressor turbina rolamento da k80e guerosene ou desel ok o kit de dentro ok |
RE: Help with translation
ran out of ideas maybe somebody else can fine tune it.
this i what i got know was the pressure of the turbine of avulssas personal helicopter inside the turbine compressor shaft bearing k80e of guerosene or desel ok within the kit ok. hope this gets you nearer brian |
ORIGINAL: lov2flyrc A customer has written me the following, seems I am unable to translate this to english... can anyone tell me what he is asking? guero saber o presso das pessas avulssas da turbina de helicoptero a parte de dentro eixo compressor turbina rolamento da k80e guerosene ou desel ok o kit de dentro ok " war know the pressure of the turbine of avulssas personal helicopter inside the turbine compressor shaft bearing of k80e guerosene or desel ok within the kit ok" |
ORIGINAL: rjbob ORIGINAL: lov2flyrc A customer has written me the following, seems I am unable to translate this to english... can anyone tell me what he is asking? guero saber o presso das pessas avulssas da turbina de helicoptero a parte de dentro eixo compressor turbina rolamento da k80e guerosene ou desel ok o kit de dentro ok '' war know the pressure of the turbine of avulssas personal helicopter inside the turbine compressor shaft bearing of k80e guerosene or desel ok within the kit ok'' LOL...yea, thats about what I got too. Still have no clue what he is asking [&o] |
Hi Todd, here it goes:
" I would like to know some K80-E parts prices: Compressor Turbine wheel Shaft tunel Shaft Bearings." I think that´s it. Regards. Achilles. |
I think he may be asking if kerosene or diesel is ok to use as well?
Many thanks guys, this helps greatly!
Mochas Gracias |
| All times are GMT -8. The time now is 11:17 AM. |
