RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   RAM 500 problem. Help please (https://www.rcuniverse.com/forum/rc-jets-120/89091-ram-500-problem-help-please.html)
jason 03-27-2002 10:39 PM
Now the system is instaled in my maverick I have powered everything up and the EGT temp is eratic when sitting on the bench, to the point that it tries to cool the engine down as it thinks it's 300 deg. This seems to hapen when the TX is within 12 inches of the ECU, surly this can not be ok can it?
jason
David Gladwin 03-27-2002 10:53 PM
Jason,
Move your Tx away to at least 13 inches !! You will need to when you fly it !.
BRG,
David
jason 03-27-2002 11:02 PM
David,
SO is that normal and is your the same?
jason
ghost_rider 03-27-2002 11:03 PM
Check your EGT probe and make sure that it is not inserted too deep.
jason 03-27-2002 11:05 PM
Ghost rider,
it,s in 1/6th inch but it's not that as the engine has not run so is not warm.
thanks
jason
Laura H 03-27-2002 11:07 PM
Jason,
Run the engine and see what happens on a range check!!!!!! By moving the tx away....Seems just like an engine we had, not so long ago!
:confused:
ghost_rider 03-27-2002 11:10 PM
Originally posted by jason
Ghost rider,
thanks
jason
Hmmmmmm. That is new to me.
I will go with David's suggestion above.
ghost_rider 03-27-2002 11:16 PM
Originally posted by Mick - Laura
Jason,
:confused:
It is 6:13 P.M here in Indiana. It should be around 13 minutes after midnight in your neck of the wood. What are you guys doing up by this time of the day.
Just kidding!!!!!!
David Gladwin 03-27-2002 11:20 PM
Dont know Jason but it is possible that you are inducing RF into your EGT probe/ECU by the close proximity of your Tx. Try changing frequency and , seriously, just moving you tx a little way from the ECU ! The RAM 500 is a gem but max depth of the EGT probe is just 1/16th inch.
BRG,
David.
Laura H 03-27-2002 11:20 PM
Its 11.17 not 12.17pm.....Your thinking we are an hour ahead clocks go back the weekend. So then your be 2 hours out!
David Gladwin 03-27-2002 11:23 PM
Mick,
In my neck of the woods its 1020 AM just enjoying my morning coffee and hoping I can burn some Jet A tomorrow if these thunderstorms stop !
BRG,
David
jason 03-27-2002 11:37 PM
David,
I'll try changing the Xtal and see what happens.
jason
jason 03-28-2002 12:06 AM
Still no joy
Well, Ive tried changing the Xtals and it was just the same, I have also tried th TX on PPM modulation, taken the Jaico reg out of line, pulled the ECU out the plane, disconected all other servos ect and it still does the same thing, so if the TX gets anywhere near the ECU or the GSU (or whatever RAMs term for the info screen is) the EGT rockets up to 300+ degrees and it then starts to cool it down cos the ECU thinks the engine is hot.
ANY MORE IDEAS ANYONE???
sirrom 03-28-2002 12:13 AM
RAM 500 Problem
Jason,
Your EGT Probe may be malfunctioning. Or you maybe getting interference on the ECU itself from your Transmitter. Where is your receiver antennae? Is it close to the ECU/or the EGT probe? If so try moving them. If not then I would call ram and see what they say. The motor is a gem and is a delight to run once setup correctly.
Patrick.
Laura H 03-28-2002 12:21 AM
When our engine probe played up it didn't switch its self onto fuel was just running on gas....But suppose if its a dodgy connections could still play up, but probably more like a faulty ECU...Look at a bloke who ive told you about before tapping the ecu and engine stopped.
TonyF 03-28-2002 12:30 AM
It's really simple, just collapse the TX antenna or have it more then 1 foot away. I have never seen this on 72/50 mhz radios here but it is possible on the 35 or 40 mhz system you're probably using that you could get some RF swamping going on. I see this with my 8417 servo on the rudder of my Bandit. If I get the TX antenna right next to the fin it will jitter. Solution, I don't fly the model within 6 inches of the TX!
Seriously, I would make sure to do a thorough range check before you fly.
Laura H 03-28-2002 12:39 AM
I wonder what will happen at a jet meet having a person on a close requency next to you
jason 03-28-2002 12:46 AM
Thanks for the reply Tony,
I will speak to the UK importer tomorrow to see if he has heard of this before.
Jason
Brian B 03-28-2002 12:51 AM
Interference
I have a few planes that go nuts when I lay the Tx antenna across the wing or fuselage. The solution: Don't do that!
WHMC 03-29-2002 02:38 AM
Brian B, What is your E- Mail Address? Would like to make contact! Thanks WHMC
Brian B 03-29-2002 05:50 AM
E Mail
Is is [email protected]
