RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   GEAR DOOR CLYS (https://www.rcuniverse.com/forum/rc-jets-120/9348153-gear-door-clys.html)
frank tum 12-21-2009 09:16 AM
GEAR DOOR CLYS
HI
IM TRYING TO FIND A GOOD GEAR DOOR CLY THAT WONT LEAK DOWN.IS THERE ANY OUT THERE.
GSR 12-21-2009 12:08 PM
RE: GEAR DOOR CLYS
BVM
ianober 12-21-2009 12:28 PM
RE: GEAR DOOR CLYS
Ultra precision cylinders and valves are very good as well.
k12rc 12-21-2009 01:53 PM
RE: GEAR DOOR CLYS
try clippard minimatic I think this came from Mc Gordon great store
http://www.clippard.com/store/cart_view.asp
Dave Wilshere 12-21-2009 02:01 PM
RE: GEAR DOOR CLYS
UP are the best. BVM very good, anything chinese....[&o]
Jet 1A also make some cylinders which will be very good.
Dw
Alex48 12-21-2009 02:14 PM
RE: GEAR DOOR CLYS
Go with the UP, never had any problems with these...
Alex
frank tum 12-21-2009 07:50 PM
RE: GEAR DOOR CLYS
THANKS GUYS FOR THE INFO
Don Y 01-06-2010 09:11 PM
RE: GEAR DOOR CLYS
consider Jet Model Products (Tom Cook), None better!
Shaun Evans 01-07-2010 03:49 PM
RE: GEAR DOOR CLYS
ORIGINAL: Dave Wilshere
Dw
:eek:
There goes that broad-brush again! Yellow Aircraft are excellent and DO NOT LEAK. A few companies bought and repackage them under their own brand names, until they went with the lower-bidding cheap junk. Nobody's ever bought an ARF from us and then found that they had to throw away the installed cylinders....
Dave Wilshere 01-07-2010 04:03 PM
RE: GEAR DOOR CLYS
Sorry [:o] It's been my experience, though my P-38 Lightning cylinders are good. We don't see many Yellow jets in the UK, I'm sure there are a more and more getting it right. Earlier experience was not good, but people learn quick.
Dave Wilshere
Shaun Evans 01-07-2010 04:35 PM
RE: GEAR DOOR CLYS
Dave,
You've had Y/A cylinders leak? I don't ENTIRELY disagree with you because there's a new Chinese ARF mfgr popping up every day and the lame cylinders seem to be one of the things they have in common. Our cylinders haven't only recently started working, however. I still can't understand why anyone would send stuff out the door without testing it (or, at least sampling it).
Dave Wilshere 01-07-2010 05:20 PM
RE: GEAR DOOR CLYS
NO! Sorry I'm obviously not clear.
I have a P-38 and the cylinders are 4-5 years old and still don't leak.That is my only experience.
I do agree that there has been a lot of stuff sent out that wasn't developed or tested. For a long time it was a joke at UK meetings about gear working. It's improved a lot recently for sure, but it needed too.
It's not easy on small dia rams, tolerences are much tighter, some problems are simply down to undersized rams being used...
Dave
[email protected] 01-10-2010 11:16 AM
RE: GEAR DOOR CLYS
I can say that the Ultra precision cylinders will not leek at -5 degrees here in Alaska.
figueroa 01-10-2010 03:09 PM
RE: GEAR DOOR CLYS
Robart makes a good gear door air cylinder. You can get them throught Tower or directly from Robart.
www.Robart.com
