retracts for 30 pound jet?
what is a good spring air retract for 25 pound jet?
spring air
Why does it have to be spring air?? The Robart 630 series would be a good choice. Spring air makes a 400 series that is similar to the Robarts.
Vin... |
25lb Retracts
Hi Pegasus
Just got in the 400 series retracts for our Roo last night. Very beefy. Since we intend to do a lot of grass flying, we shouldn't be able to bend these. Ed |
Retracts for 25-30# Jets
I agree with both of the previous posts.
I have used BOTH sets and like them equally as well and ALL my flying is off grass. I have S/A 400's w/1/2" Robo-Struts in my ARES design. It weighes in at 23# Dry/28.5# Wet. Not a single issue. Based on a COST ONLY evaluation, go with the 400 S/A. I would suggest that you check-in with Sonny at B&D Gear as well. Kerry S. |
Thanks guys
Vin, I figured the Sping air were resonably priced I actually have not checked out the robart |
Pegasus- Check out the JPM web site . Their gear is some of the best and most reliable i've ever seen.
Marty O |
I JUST ORDERED A SET OF 630'S WHAT NOSE UNIT DO YOU RECOMEND? THIS IS FOR MY ROO BTW!!
SCOTT |
| All times are GMT -8. The time now is 08:16 AM. |
