Arctic P80 SE!
RE: Arctic P80 SE!
Very expensive snow remover :D
Paul |
RE: Arctic P80 SE!
You better watch out your neighbors will want you to clear their drive way also if they see your fancy snow blower:D:D:D
RE: Arctic P80 SE!
You nutcase!
Can't believe how cool your turbine is running! |
RE: Arctic P80 SE!
Things we do in this hobby.:D How long is your summer flying season? The F 104 looks like it might fly better than it handles as a snow blower.
Semper Fi Joe |
RE: Arctic P80 SE!
haaaaaa Thomas that was AWESOME.
RE: Arctic P80 SE!
Cooling was ok today! I believe I also got very good thrust...Gary, whats the normal temperature range? Must be 150 or so more?
We can fly jets for about half of the year, now is the hardest winter in a long time. Tuomas |
RE: Arctic P80 SE!
I was in Finland in 1968 and it was soooooooo cold!.. plus lots of snow lol!
RE: Arctic P80 SE!
In the summer it gets really bright, there is almost no night for a month.
The P80 SE is a really smoothly running, quiet turbine with a fantastic howling sound that fits the Starfighter perfectly! I'm impressed that it started and ran flawlessly in this weather! TP. |
RE: Arctic P80 SE!
Yes, I get up to 550 near 600 sometimes.
RE: Arctic P80 SE!
I also love my SE or though my late 80 has been a good engine so far, 75 flights.
RE: Arctic P80 SE!
One of the nicest F104 decent plain Ferrari red . Post some more pic pls...
RE: Arctic P80 SE!
Good thinking!!! Diggin the FERRARI paint!! |
RE: Arctic P80 SE!
1 Attachment(s)
Hi, I like it too! Here are some pics. Sadly on the third flight I ran off runway in crosswind and broke the nose cone. The pitot caugt into the vegetation and buried the nose into the ground. However, I glued it together and flew it for total 12 flights last season. Now a new nose and tip tanks are slowly materializing in my working room. Ralle will supply new decals. So the red beast will surely fly again...
BR, Tuomas |
RE: Arctic P80 SE!
1 Attachment(s)
The new nose and tip tanks are in this state now...I´m thinking of the paint job...have to decide to whether do it myself, or use a local car paint shop.
TP. |
RE: Arctic P80 SE!
Tuomas hi,
What is the 104 like to fly, is it a nice flying machine, or has bad vises ??? Ive liked the look of them, and keen on Avonds kits, so maybe like to do one... chrs Jeremy. |
RE: Arctic P80 SE!
Hi Jeremy,
its a really stable model to fly. It will not tip stall, or be critical in any sense. Only problem may be seeing it correctly in the sky, the tip tanks help in this matter-it is never to be flown without them. The reason I broke mine last season was excessive nose weight and sluggish nose wheel. The room inside is limited, so installing all the equipment CG wise is difficult, of course depending of how big main fuel tank you have. Mine is 1, 5 L (+ 0.7 in two saddles) and that is too much, might just change it back to 1.2 L to keep the nose lighter. Now I just turn the breathing brass tube as horisontal I can to avoid the main tank going completely full. I also had a lighter turbine , a G-80 in the back before, now there´s the less thirsty Jetcat, albeit its bigger an heavier. I have the scale undercarriage, and all the valves and sequencer takes room and make the model quite complex. But, it looks really dangerous in the model field, and usually draws lots of interested onlookers around. The takeoff run is long, so a short grass field will not do. But in a longer one it flies well. If You build one, You probably end up having lots of fun with it! Its also simple to assemble in the field, just the nose with 4 screws and one servo line + pneumatics with BVM EZ-air, and You´re done. Landings will never be long, it drops like a brick when throttle is pulled back. And its faster than it looks as the long fuse lures the eyes in the sky a bit. TP. |
| All times are GMT -8. The time now is 04:00 AM. |
