RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   Flycamone ECO and Futaba - PROBLEM SOLVED! (https://www.rcuniverse.com/forum/rc-jets-120/9520302-flycamone-eco-futaba-problem-solved.html)
icepilot 02-20-2010 12:04 PM
Hi guys!
I recently bought a Flycamone ECO to use in the cockpit of my F-16. It works great when operated
manually, but when I plug it into my Futaba FASST 14 ch receiver, it does not react to any kind of
input, even tried reverse, a lot of different ATV setting etc - no go! So I had another one sent from
UK, same thing. Tried hooking it up to my old reliable Futaba 9c, no go. Tested both on a JR Spektrum -
works like a charm!?! [:-] So has anyone plugged these into a Futaba system and made it work? We tried
2 different Futaba FASST receivers and the 35 Mhz today, 4 smart guys present - nothing!
Any tips, anyone???
Tor
madmodelman 02-20-2010 12:14 PM
RE: Flycamone ECO and Futaba - PROBLEM SOLVED!
Tor, have a look at this,
http://www.jperkinsdistribution.co.u...=1&Navmain=R/C equipment&subcatname=Flycam & accessories
Gary.
icepilot 02-20-2010 12:17 PM
Thanks, Gary - this is the ECO version that is powered from the Rx and comes with the servo cable, ready for Rx operations,
so it needs nothing but a free channel to operate (or so they claim..:D)
HarryC 02-20-2010 12:20 PM
I would have a guess that the flycam has fallen victim to the very low voltage that Futaba is now putting out on the data signal pin. There have been other devices which have not worked with the modern Futaba receivers because of this. The devices read the voltage as permanently low signal or as non-existent, so they don't see the PPM wave form to respond to. Ideally Flycam should modify their design to work with Futaba's low voltage, but failing that a signal booster between the Rx and the Flycam will probably fix it.
Harry
madmodelman 02-20-2010 12:20 PM
Hmmmm. Strange it works on Spektrum & not Futaba.
I would have tried like you max ATV, can't think what else could be different, do you have or have you tried subtrims to try and alter the endpoint throws?
madmodelman 02-20-2010 12:22 PM
Ignore that, Harry is probably right.
mr_matt 02-20-2010 12:46 PM
Hi Tor,
Just a guess, but this could be caused by the signal voltage (limited to a low level by Futaba) and the battery supply voltage being too far apart.
You can reduce the battery voltage or you can boost the servo signal voltage.
hooker53 02-20-2010 01:56 PM
Wonder if that switch will work with all Ver. of the Flycams??? Like to find one stateside!
Roy
wikman 02-20-2010 01:58 PM
Hej Tor
Du behöver en sådan här så fungerar allt igen.
http://powerbox-systems.com/e/powerb...rker/start.php
Vi syns i sommar
Anders
icepilot 02-20-2010 02:20 PM
Hej Anders!
Vi koblet den opp gjennom en powerbox, det fungerte ikke, og jeg trodde også at den gamle 35mhz-mottaker hadde
høyere spenning?
I tried all the ATV/Reverse/Subtrim tricks in the book, and even connected it through a powerbox, still nothing... :eek:
And I thought it would work with the old 35Mhz-rx...but no..
wikman 02-20-2010 02:55 PM
Hi Tor
I am not shore this will solve the problem but give it a try.
Set up the travell adjustment to max, it sounds like a to short adjustment.
/Anders
icepilot 02-20-2010 03:33 PM
I did all that, travel to both max, min, middle, sub trim from top to bottom, 4.8V, 6 V - nothing...
SAP_2000 02-20-2010 06:07 PM
Tor: Like I said to you earlier today, Switch to a JR ;) :D
icepilot 02-20-2010 06:12 PM
Staale -
I'd rather collect old rocks and play with them in my back yard ;)
f40fanatic 02-21-2010 01:39 PM
how do you make the flycamoneeco work manually?
thanks dave..
icepilot 02-21-2010 01:58 PM
You just connect it to a free channel so you see from the green LED that it has power.
Then you push the small white switch (dot) at the bottom of the print, and it will start
recording, indicated by the LED turning red.
Tor
f40fanatic 02-21-2010 02:01 PM
but i got mine in a futaba fasst receiver and i connect it up and no light comes on at all?
Dave
icepilot 02-21-2010 05:35 PM
The problem may be that the voltage from the Futaba receivers is marginal for these -
I have sent a request to the manufacturer and will hopefully have an answer tomorrow.
Tor
mr_matt 02-21-2010 05:48 PM
Hi Tor,
No offense like I said I think this is the problem.
http://www.rcuniverse.com/forum/fb.asp?m=9520403
icepilot 02-22-2010 01:54 AM
Hi Matt - how do I boost the voltage, do I need a small servo booster?
mr_matt 02-22-2010 02:27 AM
Hi Tor,
Yes, you need to get the signal voltage (yellow or orange wire) and the supply (battery) voltage closer together. You can do this by boosting the signal or lowering the supply voltage
As a quick test, have you tried this device with a plain 4 cell NiCad? This will get the supply voltage lower and closer tot he regulated output of the Futaba.
Regards,
ela 02-22-2010 05:07 AM
Interesting problem. But ofcourse if you really need a powerbox to get the camera working I wil say the Flycam guys really have a bad design.
It can make sense that it doesn't work on Fasst but when you have also tried the 9C i will say the design is bad. This should be compatible with most rc stuff. You could for a test try channel 9 on the 35 Mhz receiver with the 9C. This is a on/off channel and not proposional. It may make a difference.
icepilot 02-22-2010 05:25 AM
Thanks for the tips, Matt and Ela - just tried both your suggestions, still nothing. NiCd 4-cell and channel 9 on the 9c, absolutely no
reaction at all. Both cameras work just fine on the Hitec servo tester and the JR radio - very strange...
Tor
icepilot 02-22-2010 05:35 AM
OK guys - I just spoke with the manufacturers of Flycamone, and a technician told me that the first (present)
badge of cameras are in fact NOT working with the Futaba systems, as they have a different pulse length than
all other systems! They will have new (and smaller) cameras that work with Futaba systems ready in about 3-4
weeks and offered to replace mine with the new ones, and I am happy with that!
Problem solved - myth confirmed!!!:D:D
Tor
SAP_2000 02-22-2010 06:21 AM
ORIGINAL: ela
Or that Futaba have a bad design. Lowering the signal voltage to 2,5V or something, when the standard have been 3,5 volts or something for decades that all manufacturers and aftermarket products like servos, powerboxes etc. use.
There also have been some issues with the compability between some powerboxes and Fut 2,4 6014 receiver. They had to go back to the manufacturer for a uppgrade in order to work reliable.
http://www.aircraftinternational.com.../PowerBox.aspx
