RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   mibo a 10 help and advice (https://www.rcuniverse.com/forum/rc-jets-120/9522869-mibo-10-help-advice.html)
jon sykes.1 02-21-2010 11:34 AM
I am thinking of purchasing a mibo a10,and would appreciate any advice and tips on it.I am interested in feedback on what its like to live with it,ie transporting,storing,the amount of time it takes to get it ready to fly etc.I have made enquiries about the possibility of having the fuselage made in two sections to help with transport,and this is possible,what do you a10 owners think.Unfortunately there is no one else around my area who owns one to ask or look at,and would appreciate any feedback before I comit to a v. expensive project that could end up biting me in the arse! I have 2 new Wren 160s already earmarked for this,so chuck in your 2 cents worth on the engine choice. The other factor is I am paraplegic so realise I may struggle a bit rigging it, but I`always fly with my son ,and a few mates so shouldnt have too much trouble coercing them into lending a hand!
I already own a comp arf eurosport and boomerang xl so struggle anyway,so figure this cant be any worse can it? Thanks in advance ,best regards Jon .
Roger Shipley 02-21-2010 12:52 PM
RE: mibo a 10 help and advice
<p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Arial; font-size: 9pt">Hi Jon, the MIBO A-10 is a 2 person assembly regardless of your physical condition but very straight forward, just slide the wings on the wing tube, insert 2 bolts on the top surface of the wing, insert 2 bolts to attach the tail feathers, assuming you removed them for transport, air/fuel up and enjoy the most user friendly, as well as forgiving, jet you have ever flown.
Your pair of Wren 160s is perfect for the MIBO A-10 and one will definitely bring it home just ask Ron Ballard the US Wren Distributor ([email protected]). I witnessed, as his caller, a flame out on t/o, climb out, several 360s and the like, and landing without any damage.<o:p></o:p></span></p><p class="MsoNormal" style="margin: 0in 0in 0pt"><span style="font-family: Arial; font-size: 9pt">Do it and keep us posted, Roger<o:p></o:p></span></p>
Edgar Perez 02-21-2010 04:03 PM
Does one need a trailer to transport it? I wonder if it would fit in a large SUV?
CraigG 02-21-2010 05:07 PM
ORIGINAL: Edgar Perez
It will just fit in a Suburban size SUV, taking up all the room and with the nose almost between the front two seats. This is with the tail section attached and the wings placed along side. The support equipment can be placed underneath to support the fuselage and along side as well. Just barely enough room.
Craig
ddennison 02-21-2010 07:32 PM
I transport mine in a trailer, tail on all of the time. I can slide it out and still support the nose on the trailer floor, and place a support under the tail. This allows me to put each wing on and then test and drop the gear. Then I can roll it along. I almost always have some help but I am not to dependent on others.
It is not too much more than putting a Carden together at the field.
I think having the fuse in two parts would be a pain to have to plug everything together and then bolt it etc...not to mention the weight increase that would be necessary.
The plane is a piece of cake after the assembly.
Good luck,
Dave
RonLongAZ 02-21-2010 08:29 PM
1 Attachment(s)
I use a 6 by 10 trailer for my hog, and this custom made cart. it is easy to assemble on the cart test the gear and go!
Here is also a few other pics.
Ronald R Long
JP-1 02-22-2010 08:05 AM
Jon,
Talk to Ali (Al's Hobbies) he will be your best source of information on this model.
jon sykes.1 02-24-2010 11:46 AM
Thanks for the replies so far any one got any install pics or a build manual?and Ron thanks for the great pics,but isnt there something wrong with your camera,the sky looks a strange blue colour! much prefer our monochrome grey version,not!!!! regards Jon
Roger Shipley 02-24-2010 12:03 PM
Yea Jon, go to: http://jetadic.com/and click on <font size="4">"A10 Instructions"</font>
RonLongAZ 02-24-2010 12:30 PM
ORIGINAL: jon sykes.1
LOL thats Funny!
Ron
schroedm 02-24-2010 01:30 PM
1 Attachment(s)
Jon,
Here's the transport setup we spoke about....
Rgds,
Mark
Roger Shipley 02-24-2010 03:33 PM
Say Mark that cradle is most interesting...would you please post some detail pictures?
Thanks, Roger
schroedm 02-24-2010 03:43 PM
Roger,
Sorry - that's your lot! Just took a quick snap when at JetPower as I thought it would serve to provide ideas for one if I went down the A10 route....
Rgds,
Mark
rcavi8ter 02-24-2010 04:15 PM
Roger I am sure Jim can work off of that picture.
jon sykes.1 02-27-2010 05:54 AM
Hi guys ,can anyone with an a mibo give me a measurement across the rear engine pods,widthways,also the tailplane with verticals?Just trying to figure out if it will fit in my car!
Regards Jon Sykes
Roger Shipley 02-27-2010 06:14 PM
Jon the nacelles are 32" wide...the verticals are 44" wide.
jon sykes.1 03-04-2010 05:41 PM
Thanks Roger for the measurements,would like to know what servos and radio most people are using,so I can get an idea of the cost for a typical install.I was thinking along the lines of power box royal ,with 2 12 channel recievers,but not sure on servos. Regards Jon Sykes
Roger Shipley 03-04-2010 06:19 PM
Jon we are using JR 8611s all around except for smaller JR servos in the rudders. R1221 RX with the redundant battery connectors was our choice without a power box but, as I recall, 3 match boxes.
JackD 03-04-2010 10:25 PM
1 Attachment(s)
Edgard
My dad transports his in a SUV (mercedes ML). He made the nacelles easy to remove with quick disconnects for the turbines. It is so tight he has to remove the gun barrel for the tail gate to close.... here are some pictures
Jack G
Ragz 03-04-2010 11:35 PM
1 Attachment(s)
ORIGINAL: Roger Shipley
Thanks, Roger
Hello Roger,
here is another view of the Hog cradle that Mark posted.. I took this pic at JP09 as well thinking that I will get an A10 as well.... :) Whats the deal on the big ones? Can you email me about them Roger? thanks in advance.
Cheers
Anurag
Roger Shipley 03-05-2010 12:43 AM
Oh yea thanks Anurag, I got to get this to Jimbo ASAP.
We were cutting ply wood yesterday on our new cradle.
He want tell me his design that is all in his head...we sometime call him Holmes.
Anyway justsubscribe to: MIBO A-10s Updateand you will get updates as pictures, etc become available.
http://jwm2011.com/
Ragz 03-05-2010 01:06 AM
Thank you, Roger...
Regards,
Edgar Perez 03-05-2010 11:33 AM
Thanks Jack G.
jon sykes.1 03-08-2010 11:44 AM
Well,finally gone and done it ,I ordered my a10 so no going back now![X(] All i need now is some one to let me know whats the best catergory to list human body parts in,on Ebay.;)
Ive got a spare kidney,should fetch enough to finish the a10 off,with all the toys my sons hoping to put on it!!!!! Please feel free to post pics of your installs etc or bid on the kidney!!
Regards Jon . Ps any one got any good colour schemes for an a10 (I know I spelt colour wrong but it just doesnt look right without the u !!):D
A10FLYR 03-08-2010 12:54 PM
ORIGINAL: Ragz
Thanks, Roger
Hello Roger,
Cheers
Anurag
Those of you who are using trailers please add a third support under the nose! (Just ask me how I know.) :( It seems that the bouncing in a light trailer stresses the fuse more than when hauled in a SUV.
