RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   KingTech K-80 (https://www.rcuniverse.com/forum/rc-jets-120/9625485-kingtech-k-80-a.html)
Jetpilot24 03-30-2010 07:42 PM
KingTech K-80
1 Attachment(s)
I just recieved my KingTech K-80. I did get it mounted on the test stand and had the opertunity to run it up. All I can say is WOW. She fired right up with NO adjustments needed to the ECU. I did 2 run ups on her, and she ran perfect both times. I plan on doing a few more test runs this Friday 4-2-2010 at the Nighthawks in North Jackson, Oh. Anyone wanting to see this new motor is welcome to come out.
Once My F-86 is done, it will be the home for the K-80. I will post pics of the install in the F-86. The F-86 is going to make a good platform for the K-80 as it is 17.5 pounds of thrust.
Here a few pics of it on the test stand.
Joe Lewis
KingTech Rep.
hooker53 03-30-2010 07:54 PM
RE: KingTech K-80
Joe, Welcome to Club Kingtech!!
marquisvns 03-30-2010 08:07 PM
RE: KingTech K-80
Congrats Joe, even I couldn't wait to see this engine in your F-86
Barry
www.kingtechusa.com
causeitflies 03-30-2010 08:10 PM
RE: KingTech K-80
Wish I didn't have to work Joe. I would be there to see the KingTech.
mun_iz 03-30-2010 10:52 PM
RE: KingTech K-80
Hi,
Yes, there is only 1 small adjustment you will need to make to your ECu setting... that is to lower down your glow plug power from 40 to 30...
check out http://www.rcuniverse.com/forum/m_92..._1/key_/tm.htm
Enjoy =)
Isaac
ORIGINAL: Jetpilot24
Joe Lewis
KingTech Rep.
marquisvns 03-30-2010 11:29 PM
RE: KingTech K-80
The factory sets it pretty hot at 40, but at the same time this ensures a quick ignition, if anything, the included medium heat plug might wear out a little sooner. So, Isaac, you are right, one might dial that down a little, and it should still fire up quickly.
I personally have a surplus of medium hot plugs (Fox standard Long) and I dialed it down to 20 or there about and still fires up every time on the first attempt.
Have lots of fun with K-80s guys,
Barry
www.kingtechusa.com
Jetpilot24 03-31-2010 05:44 AM
RE: KingTech K-80
Thanks for the warm welcome to the family. I am looking forward to getting this motor in the F-86. Here is the link to the build.
Joe Lewis
KingTech Rep
Jetpilot24 04-03-2010 01:59 PM
RE: KingTech K-80
I did 2 more runups on with the K-80 on the test stand Fri. Both went very good. I did some simulated flight by running where I thought it might run in the F-86. She never missed a beat. I did some slams from idle to full throttle and back. The K-80 ran flawless. Now I just need to get the F-86 finished and get the K-80 installed.
If anyone is thinking about a 17Lb thrust motor, the K-80 is the way to go. Barry with www.kingtechusa.com and he will get you set up.
Joe Lewis
KingTech Rep
Aero65 04-03-2010 11:30 PM
RE: KingTech K-80
Hello All
Here is my JL F-4 with twin kingtech K-80's great turbines.
[youtube]http://www.youtube.com/watch?v=clBibvtjQjQ[/youtube]
Got mine from Todd at dreamworks, also a great person to deal with. It's so cool that Kingtech in the US has such great support.
Aero65 04-03-2010 11:32 PM
RE: KingTech K-80
Here is my Avonds F-104 with the K-80
[youtube]http://www.youtube.com/watch?v=z82WtqRedDk[/youtube]
Great turbine, I really like my 2.
yeahbaby 04-04-2010 10:18 AM
RE: KingTech K-80
damn Duke that thing was moooooooving!!!! nicely done
you lucky dogs livin on de aiiiiiiisland bruh'
hooker53 04-04-2010 10:32 AM
RE: KingTech K-80
ManI can't believe the sound these Kings make and that 104 was moving and with just 60% most of the time!!! Can't wait to get mine mounted.
Jetpilot24 04-04-2010 11:47 AM
RE: KingTech K-80
1 Attachment(s)
Guys
The F-4 and the F-104 look great. Looks like there is alot of push on both of them witht he K-80, sounded good too. I can't wait to get mine in the F-86.
Joe Lewis
KingTech Rep
hooker53 04-04-2010 12:38 PM
RE: KingTech K-80
Joenice looking 86. be sure to get some footage of the maiden with the KingTech. Is everyone using turbine oil or has anyone tried the DTE-Lite on these???
Shaun Evans 04-04-2010 01:40 PM
RE: KingTech K-80
Hi,
What make is the Sabre?
marquisvns 04-04-2010 02:03 PM
RE: KingTech K-80
ORIGINAL: hooker53
Hi Roy, I actually had the first 25 hours on my #100 with Shell's counter part of Mobile DTE-Lite, the Shell Tellus 32, with no more than average carbon built-up. I also have buddies using 2 cycle oil with good result, but good old turbine oil is what the factory currently endorses.
If anyone wants to use anything other than turbine oil, please let us ok it first, so that the warranty will remain effective. Meanwhile, we'd be able to gather more data and learn from one another.
Thanks in advance,
Barry
KingTech USA Int'l
hooker53 04-04-2010 02:29 PM
RE: KingTech K-80
Barry, So DTE-Lite is ok as per Factory?? AlsoHope you are having a very Happy Easter!!!
Jetpilot24 04-04-2010 02:58 PM
RE: KingTech K-80
ORIGINAL: YellowAircraft
Hi,
The Sabre is an HP Jets F-86.
Here is a link to the Rebuild thread.
It was actually a kit. Remember when we use to build kits?:)
http://www.rcuniverse.com/forum/m_9277032/tm.htm
Joe Lewis
KingTech Rep
marquisvns 04-04-2010 04:02 PM
RE: KingTech K-80
ORIGINAL: hooker53
I guess the proper answer to the question would have to be "NO" for now. But as a trial purpose it would be OK (we need more data and experience in order to OK a turbine oil substitute), what I mentioned and encouraged is that if one likes to use anything other than turbine oil, please check with us first, so that the warranty will remain effective.
If you'd like to use DTE-lite, please write me a quick note through email, including the current cumulative time and I'll input it in your profile, so your warranty will remain effective.
Thanks Roy, Happy Easter to you too!
Barry
Jetpilot24 04-06-2010 03:28 PM
RE: KingTech K-80
1 Attachment(s)
She is ready for clear coat. Here are a couple of pics. She gets her clear this weekend.
Then just a matter of installing all the Radio gear and The KingTech K-80
Joe Lewis
KingTech Rep
hooker53 04-06-2010 04:27 PM
RE: KingTech K-80
Looking Good Joe. Hope your lining up your camera man for the maiden!! :D
Jetpilot24 04-06-2010 04:41 PM
RE: KingTech K-80
Definatly, I have a buddy that wants to video her on the maiden.
Joe Lewis
KingTech Rep
JOHNSCHR 04-06-2010 08:12 PM
RE: KingTech K-80
I got my Kingtech turbine in last week and am very impressed! Cant wait to fire her up this weekend.
Does anyone know of a FOD screen that fits the K-80E?
Chris
marquisvns 04-06-2010 08:14 PM
RE: KingTech K-80
Joe,
Look forward of seeing a picture of the shiny #271 in your new and improved F-86 : )
Barry
KingTech USA Int'l
marquisvns 04-06-2010 08:23 PM
RE: KingTech K-80
Chris:
KingTech Taiwan is making a FOD screen for the K-80 right now, and I should be getting them in a couple of weeks. I will email you and all the registered K-80 owner when it becomes available.
Barry
KingTech USA Int'l
