RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   FEJ L39 1/7TH (https://www.rcuniverse.com/forum/rc-jets-120/9767559-fej-l39-1-7th.html)
gtoro26 06-29-2011 11:32 AM
RE: FEJ L39 1/7TH
ssorry my bulder tossed them
i had it on r c u last year
no one bit so he tossed them
sorry
bonehead move
but i hope you dont bang yours
fly straight fly hard
but land soft
FMRR 06-29-2011 04:25 PM
RE: FEJ L39 1/7TH
ORIGINAL: gtoro26
sorry
bonehead move
but land soft
Your builder threw your L39 gear away ! [:'(] ....If your looking for a new builder now let me know. Will you be at kentucky Jets next week? maybe see you there.:D
gtoro26 06-29-2011 07:22 PM
RE: FEJ L39 1/7TH
i gave him that gear awile ago and tried to sell a few times but nothing
thats what i said
boneheaded move
anyway
good luck on yours just triple check everything
also is your nose wheel steering with that fork shaped u and a pin goes inside when wheel locks
if so you need to somehow extend the u or fork and move the pin when retracted closer to the center of the u
this is so it wont slip out at full deflection if this happens wheel slips and stays in one position
thanks
Yann 06-30-2011 12:59 AM
RE: FEJ L39 1/7TH
Never had this issue... I'll check that up tonight !!!
FMRR 06-30-2011 07:43 AM
RE: FEJ L39 1/7TH
I'll take a look and check also,thanks for the tip.I will try and get some pic's up this weekend,and post the build progress after Kentucky:D
Yann 06-30-2011 08:55 AM
RE: FEJ L39 1/7TH
I don't seem to have the problem, the fork is way long enough.
FMRR 06-30-2011 01:57 PM
RE: FEJ L39 1/7TH
Yann, I was told that FEJ now offer the up grade for the gear springs.I 'll call James tomorrow and find out for sure.
Yann 07-04-2011 01:21 AM
RE: FEJ L39 1/7TH
Any news about news springs available from FEJ?
FMRR 07-04-2011 11:51 AM
RE: FEJ L39 1/7TH
ORIGINAL: Yann
Hi Yann, I drop the ball,with the Holiday I did not get a chance to call him.I will see him in Kentucky Thur and ask.Did you find yours ?
FMRR 07-04-2011 04:33 PM
RE: FEJ L39 1/7TH
1 Attachment(s)
Hi gents ,Here are my L39 pic's
Yann 07-05-2011 03:45 AM
RE: FEJ L39 1/7TH
Nice... They seem to have improved a lot. support beams for retracts, balsa/carbon sandwich formers, overall extensive use of carbon fiber...
Mine was far from that when I opened the box.
Hope you also bought the now available kevlartank option. Mine split open twice right on the seam line... no was to fix that up.
All solved with a kevlar tank.
I'm sure it was no more pain for FEJ to make it right strait. doing it all over has been a really painful for me.
Yann 07-05-2011 04:50 AM
RE: FEJ L39 1/7TH
As to your question, I have no spares. I'll have to run to the small spring factory to have them cutom made for you from my set.
I'll do that only if bad news from FEJ about their own springs.
FMRR 07-05-2011 04:50 AM
RE: FEJ L39 1/7TH
Thanks Yann,And yes I have the kevlar tank option and cock pit.Still thinking about your flaps but something I will do later.Not sure if you are going to Kentucky Jets.I'm heading out on Thursday.
Yann 07-05-2011 04:58 AM
RE: FEJ L39 1/7TH
No, I'm not going. Flying on the french riviere is not bad either...
I don't know how much flap deflection you can get, as it seems the original setup has improved a lot.
I would still consider doing so, no matter how it looks, it works just wonderfully. The plane comes in much slower.
No matter how long your runaway is, the faster the plane at touch down, the more energy the gear/tires have to dissipate.
Furthemore, the slower you can bring your plane in, the less likely you are to damage it...
Of course, it's up to you, but keep in mind this mod is really easy/quick to do.
Good luck anyway, and keep us posted.
FMRR 07-12-2011 08:24 AM
RE: FEJ L39 1/7TH
OK it's been a few days since my last post but the trip to Kentucky was great.Time to get to work now.Yann I did meet James from FEJ at the show.He is a great guy and really stands behind the product.He does now have the new springs for the L39 gear and they are on the way.I will be starting with the wings first and will try to post the build and get some pics up for all of you who are interested. Kentucky jets is the best show on earth,Lewis is one stand up man and treats everyone like family.Great job Lewis see ya next year.
David Jackson 07-12-2011 11:55 AM
RE: FEJ L39 1/7TH
Great looking color scheme on the L-39. Is that the large one (106")?
FMRR 07-12-2011 04:06 PM
RE: FEJ L39 1/7TH
ORIGINAL: David Jackson
Great looking color scheme on the L-39. Is that the large one (106'')?
Hi David, Nice seeing you at Kentucky.If you have that picture they took of us standing by your L Viper I like a copy.To answer your question it's the small 1:7 54" WS, 71" length.My L Viper will be the same color schem but blue instead of red.
FMRR 07-14-2011 11:23 AM
RE: FEJ L39 1/7TH
Ok gents, started to sort out the FEJ wing servo trays (Flap Aileron) The parts are laser cut and when finished becomes a sandwich box between the upper and lower skin. This keeps the box from flexing and adds strength to the wing in the cut out areas. Very nice design, will try and get some pics up this weekend. Tip make sure you scuff( not sand) all the laser cut edges for a better glue joint, take your time to fit all the pieces in the proper position and you may want to add some glass cloth to the upper skin before dropping the box in. Well done FEJ very pleased. Almost forgot,some trimming to the wing openings may be needed to drop the completed box when finished.
FMRR 07-26-2011 07:39 AM
RE: FEJ L39 1/7TH
Sorry this is slow going but ran into a few snags.I decided to go with the electric modification from "Down and Lock"I will be sending the gear out today after not being able to get someone on the phone for a week.Spoke with Ron,real nice guy and said I have the gear back in three weeks.The gear will be electric and the doors will be air.The other snag is the flap sevo tray.The tray must be sandwich between the skins.On the lower skin this is done by fitting tabs between the tray and skin at each corner of the box.I cannot install the tabs in the flap opening due to the aft side the tabs are in conflict with the flap hinge support blocks.So I have come with three options to work around this.If anyone here has run into this problem let me know.I'm thinking since the hinge spar is so close to the servo tray box just to fill the gap with a solid 3/4 balsa block and have a solid connection to the tray.Also was missing one of the two push rods for the elevator,. called James and he has the replacment on the way.Thanks james.Sorry no pics but really not much to see yet.
FMRR 09-10-2011 05:27 PM
RE: FEJ L39 1/7TH
Well gents,The gear came back from Down and Lock two weeks ago and on time like they promissed(looks great/works great).James also finally sent the elevator rods that was missing from kit.Since then I pick up a new DV8R from TBM and I am now building that jet,I will get back to the L39 when the DV8R is complete.
