RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   I broke the code !!! (https://www.rcuniverse.com/forum/rc-jets-120/9836837-i-broke-code.html)
afterburner 02-23-2011 04:09 PM
RE: I broke the code !!!
ORIGINAL: FILE IFR
Danno,
I've been thinking of getting a smaller gererator like the HW2000, or the Honda one that is similar.
I've seen/heard the small Hondas in use and they're SUPER quiet... is the Honeywell just as quiet??
No. They are a bit louder and run a little rougher.
Marty
f106jax 02-23-2011 05:16 PM
ORIGINAL: FILE IFR
Danno,
Mike,
The Honeywell is not as quiet as the Honda but is not intrusive. I usually put mine just outside of my tent area in the pits with the exhaust pointed away from the tent, and it's not a problem.
rcjetsaok 02-23-2011 06:28 PM
The Honda's are quieter.... Sorry about your trouble... The key is use the choke. With the choke on it's pulling fuel only. 3 to 5 pulls and mine starts right up. I turn my fuel off and let it run till it quits after a session. So when I turn the fuel on, the system is dry all the way to the carb... A few pulls w/ chole on and it primes it self and fires off.
Regars,
Danno
rcjetsaok 04-21-2012 06:55 PM
Well, 14 months since the last post here, and 6 1/2 months since I used my Honeywell last... Getting things ready for the season, pulled it out, wiped it off, same gas as last use, turned on the gas valve, set the choke, 4 easy pulls.... started and purr's like a kitten... Smiling here !!!:) :). Unbelievable !!!! Ready for action.
Danno
