RCU Forums
-   RC Jets (https://www.rcuniverse.com/forum/rc-jets-120/)
-   -   delete (https://www.rcuniverse.com/forum/rc-jets-120/9869368-delete.html)
Dixty 07-16-2010 03:47 PM
delete
deleted by me
bcovish 07-16-2010 04:15 PM
RE: delete
And not one fire extinguisher on site.[X(]
You are questioning a static charge. Could it have been a shorted out battery.
DelGatoGrande 07-16-2010 04:16 PM
RE: delete
ORIGINAL: Dixty
.. make sure you ground the jet <u>before</u> touching it....
?how i can ground the d@m thing with out touching it?:D
hyperdyne 07-16-2010 04:19 PM
RE: delete
Except for the fire extinguisher under the table, which nobody grabs! [:@]
E.N.T. 07-16-2010 04:21 PM
RE: delete
In seconds 218-223, you can see clearly a FIRE EXTINGUISHER under the table.
ENT
Dixty 07-16-2010 04:21 PM
RE: delete
deleted by me
bcovish 07-16-2010 04:24 PM
RE: delete
on watching it again, there was a fire extinguisher under the table. Missed it the first time.
afterburner chuck 07-16-2010 04:47 PM
RE: delete
Bob o
the fire ext is under the table not more the ten feet away. The proplem is the did not have it at the a/c
joeflyer 07-16-2010 04:57 PM
RE: delete
So you just joined RCU and this is your first post??? What is your modeling experience? It looks like you're trying to be an alarmist and don't have much knowledge of model jets.
There is no evidence that the RC jet fire in that video had anything to do with static discharge. It is not as big a concern as on full sized aircraft. There have been some ECU problems blamed on static electricity, but I have never heard of anyone blaming a model fire on static electricity.
afterburner chuck 07-16-2010 04:57 PM
RE: delete
The fuel tube that we use is not rubber its the same tube the gas guys use and the same tube is used in weedeaters and some lawnmowers
afterburner chuck 07-16-2010 05:01 PM
RE: delete
ORIGINAL: joeflyer
I agree, what is your experience with jets?
Dixty 07-16-2010 05:04 PM
RE: delete
deleted by me
SinCityJets 07-16-2010 05:46 PM
RE: delete
The video is almost a year old and has made the rounds on RCu a few times. Not sure where you are coming from (or trying to go) with this. I would have to put the total number of spontaneous combustion occurrences from touching jets at negative one (-1). I have actually seen -1 of them.
Now for some advice people CAN use. Do NOT use your jets at a BBQ. No matter how good the carne asada from Dougy is, it is NOT worth lighting your jet on fire to cook it!
well, maybe just a wing or something :)
Chad
highhorse 07-16-2010 06:07 PM
RE: delete
Dixty: I suppose ur heart is in the right place, that u mean well, and u just want to make a meaningful contribution to the hobby. Good on ya for all of that.
It's a shame to see u attacked for trying to help.
But... surely, if this were a valid issue then we'd also be hearing about it from the gasser guys because gasoline vapors are so much more volitile. Or the tons of very, VERY experienced folks in the jet side of the hooby would have stumbled across and recognised it before now. Many of these folks have extensive aviation backgrounds and the concept of static discharges is not a new one to them.
And I can't remember anyone ever mentioning being "electroshocked" by a model of any type.
Never say never...but this threat just doesn't seem to be a "thing", ya know? Thanks for trying tho.........
rcjetsaok 07-16-2010 06:11 PM
RE: delete
ORIGINAL: E.N.T.
ENT
After reviewing the Zapruder film Frames 218 to 223, I have to agree with the single bullet theory. I didn't see anyone on the Grassy Knoll !!!!! :D:D.... Give me a break !!!!!!
Danno
cloudancer03 07-16-2010 06:24 PM
RE: delete
THE FIRE EXTINQUISHER IS IN PLAIN SIGHT !!!! WHY DIDNT ANYONE THINK TO GRAB IT?
AndyAndrews 07-16-2010 06:51 PM
RE: delete
Over 1500 flights of non grounded jets at KY jets. Not one fire caused from static. This is bunk. I've never once heard of a jet catching on fire from not being grounded.
AFTERBURNER1 07-16-2010 07:00 PM
RE: delete
1 Attachment(s)
Just let the thread die and Capt 3 post will be gone.... KABOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOm!!!![X(]
Bryce Watson 07-16-2010 07:08 PM
RE: delete
Yea, and just like [link=http://www.youtube.com/watch?v=ZlCLuIwuVgQ]Eminem[/link] says, [link=http://www.youtube.com/watch?v=2rhPux0EIPA]"I'm not afraid"[/link] of any of my jets catching fire, because they're always grounded anyway, especially when I'm not flying them! :)
Now on a more serious note, I have always seen a grounding wire connected to real planes when fueling/defueling, but what do I know, I just stayed in a Holiday Inn Express last night.
:D
joeflyer 07-16-2010 07:20 PM
RE: delete
The difference is that with our models we do not pump enough volume of fuel at high enough velocity to build up a significant static charge.
Joe
Bryce Watson 07-16-2010 07:28 PM
RE: delete
ORIGINAL: joeflyer
Awww man, see that? [:o] All this time I've been waiting for Tamiya to come out with that big fuel truck with the six wheels on each side that holds 5 gals of Jet A so I can get some realism points with a miniature static grounding wire! :D
invertmast 07-16-2010 07:30 PM
RE: delete
Ok... tell me this.
How are you going to electrically "Ground" an airplane when about 90% of them are made from foam, fiberglass, and balsa wood. The only things that conduct electricity anywhere "decent" (besides the electrical stuff and metal parts) is the carbon fiber in the airframes. But those are not really oriented to build a "common" ground plane that connects each piece of carbon to the next.
Most of the tanks are mounted to Wood structures.. last i checked wood SUCKS at transmitting electricity. Rubber/ tygon/ poly tubing isn't exactly the greatest either at transmitting electricity either, which is what most of us use for fuel and air lines..
Good intentions are probably intended, but its not just as simple as putting an alligator clip to the airframe with a copper wire going to a ground "stake" in the ground. Not to mention in the full-scale world, grounding of the airplanes during refueling is done b/c they are pumping fuel into the tanks a hell of alot quicker than we are, so they have a higher chance in building a large electro-static charge.
Bryce Watson 07-16-2010 07:40 PM
RE: delete
ORIGINAL: invertmast
Ok... tell me this.
How are you going to electrically ''Ground'' an airplane when about 90% of them are made from foam, fiberglass, and balsa wood. The only things that conduct electricity anywhere ''decent'' (besides the electrical stuff and metal parts) is the carbon fiber in the airframes. But those are not really oriented to build a ''common'' ground plane that connects each piece of carbon to the next.
Good intentions are probably intended, but its not just as simple as putting an alligator clip to the airframe with a copper wire going to a ground ''stake'' in the ground. Not to mention in the full-scale world, grounding of the airplanes during refueling is done b/c they are pumping fuel into the tanks a hell of alot quicker than we are, so they have a higher chance in building a large electro-static charge.
Like I said, when it comes to me and jets, it's [link=http://www.youtube.com/watch?v=yH8FZusjY94]Holiday Inn Express.[/link]
I agree with everything you guys are saying, otherwise I'd go [link=http://www.youtube.com/watch?v=pA-oyrO9Lpk&feature=related]ask a pilot[/link], and of course, more than likely get the same answer over and over again.
invertmast 07-16-2010 07:44 PM
RE: delete
holy hell that was alot of posts that popped up while i was typing my last reply. lol
trioval00 07-16-2010 07:56 PM
RE: delete
what really gets me is that in the video, the guy behind the camera focuses on the fire extingusher at 1.00 minute. Why did he say anything to the guys about that extingusher...... THEN look at 1:10, one of the guys brings over the fuel jug and attempts to defuel while the jet is burning.....................
Mark
