Falcon 120
I have a JET CENTRAL Super Bee in a Shock jet that I'm thinking about putting in a Falcon 120.Has anybody done this or do you think it would fly it ok?
RE: Falcon 120
See http://www.rcuniverse.com/forum/m_59..._1/key_/tm.htm loads if information,take the time and read the whole thread!
RE: Falcon 120
I have a super bee in my falcon. I followed the thread posted above and did most of the listed improvements. In the end, it should end up weighting around 16-17lbs and it flies great on 14lb of thrust.
Mine will maiden in a couple weeks. Good luck. Best regards, Chris |
RE: Falcon 120
I have a Super BEE in mine as well it flies great.
RE: Falcon 120
Mine flies with a P-60 and weighs in at 14 lbs.
RE: Falcon 120
have a friend who has a wren 44 in one and it flys great
RE: Falcon 120
I used to fly mine with a RAM500 (approx 12lb-13lb thrust), weights was 14lbs, until i crashed it due to a dumb thumb.
http://www.youtube.com/watch?v=TG45GvhwgLU It sure is a great flying airframe, take your time and do all the necessary changes, it will help prevent structural failures. |
| All times are GMT -8. The time now is 09:06 PM. |
