what to do with my new Terra Crusher...
My Feedback: (13)
IN
what should i do with my new tera crusher, ive been gone for a while as most of you regulars know... should i make a big block TC, show TC (aluminum stuff), racing TC becuase they have been known to be able to hold there own, thinking about even a dual engine if i can find or figure out plans to do it.
I would take the big block idea out cause anything over 2hp you'll be asking for trouble....
I would get an OS .15 CVRX engine with HPI savage tires on RPM titan offset tmaxx wheels and proline ultra firm impact foam tire inserts....
with that set up you would be ready to take any mt's one on one on a tight track....
I wouldn't waist money on aluminum hop ups they only add more weight to your truck and IMO are useless for the terra crusher cause it is built super tuff out of the box....maybe some aluminum diff cases but thats all.....
BC, CANADA
Do away with the radio box and buy a New Era radio plate, get a better .15-.18 motor such as Fantom 18 or OS CV 15 or XTM 18 and as little alum as possible (except maybe chassis braces). I was going to go with the .21 conv myself but I don't want to be breaking things, just broke/twisted 3 U-cups recently with the wimpy FS18 motor. The Crusher in stock form is already super sturdy so don't worry much about it.
My Feedback: (13)
IN
im ignoring most of what you said cuz u actually told me to put those tiny savage tires on the terra crusher, and think the OSCVR will have more power than the tamiya engine.... comment neglected. You also act as if the terra crusher cant handle the .21 engine, even though its bigger than every MT out except the Titan. do more research if ur going to suggest something :-/
My Feedback: (13)
IN
ASs far as tires goes the terra crushers tires are too heavy and take alot of power out of an engine.....When i had mine i ran it with HPI savage tires cause they were lighter aand gave more room for my engine to breath.....
If you don't know what you are talking about don't bother saying nothing at all!!!!!!!!!!!
and here is a picture of mine with the savage tires on it and RPM offset wheels on a high speed pass....
BC, CANADA
Alright, you DID ask us for suggestions and now you say you're going to ignore them. Whatever then. :P
Them Big Joe's tires would do perfectly on the TC or T-Maxx tires. As for fitting other 18's in, the XTM .18 conversion kit (for T-Maxx) has a 90-deg manifold that should work to clear the shock towers although the header might sit a little high, I haven't bothered trying the XTM .18 in the TC yet since it's bolted in the T-Maxx. I might have to do a little investigation at www.terra-crusher.com or someplace to find out. That forum also has a "fitting a TRX 2.5" article under tech tips which you might want to look at.
WY
Hmmmmm, how is that for a helpful hint :stupid:
And I believe the post right below that one said you are going to put bowties on it, hmmm well FYI those bowtie tires are smaller then the savage tires, and in the engine department, maybe you should do some more research before gracing us with your most excelent yet ignorant reasponce's. I see nothing has changed since the first time we met!! But its good to see theres some one new to argue with now LOL.
