Supermaxx tranny kit?
Well i just installed a Rix Gears FOC and it didnt even last a full tank of gas with my 24.7. So i guess this means i have to go with the supermaxx tranny kit, but i was wondering which one to go with the 8mm or the 10mm? Thanks
WY
Yup the rix is just a stock replacement.
As for the ue trannies, the 8mm was made for the smaller engines, and the 10mm was designed for the big horse power big blocks, however, the 8mm can hold up to the bigblocks just as well, its just got a smaller tooth face then the 10mm, but the gears are the same material, and the shafts they are on are the same as the 10mm.
Alright i will go with the 10 mm. wait iam looking at the website and they changed it all up they no longer have the old tranny stuff has some new prototype and that it for 99 bucks can someone tell me what happen can i still ge the old one or do i want this one, whats the deal here
http://www.unlimitedengineering.com/s-foc.shtml
only get that if you have 1/8 diffs. if you go with the 10mm you will have to mod the case in order for it to fit. but that one looks freakin awesome. i would and will get that when i go big block.
bubbafien
bubbafien
only get what if i have 1/8 th diffs the supermaxx tranny old or new and why? and what 1/8th diffs should i get i am not going to pay 350 for supermaxx diffs.
the new one is higher geared for the 1/8 diffs. i would get the supermaxx diffs. they are not 350. they are 333 for the 8 spiders, 275 for the 6 and 265 for the 4 at stormer. these are probably the cheapest you can get and definitly the best.
bubbafien
bubbafien
ok also one more question iam going to get the 10 mm older version kit with the mod tranny case. Should i use stock plastic gears with it or get RRP or something like that and if i do go with plastic with it hold up?
WY
The 10mm comes with its own modded case so it will work just fine, you wont have to mod anything just put it together with your 2 speed gears!!
Anyways, you wont need anything to complete the tranny, the only other tranny options you have are the aluminum 2 speed gears by OTB and the alloy top shaft, which the 2 speed gears are only made by 1 company OTB, and the topshafts can be bought from either UE or RRP, also you can get the 10mm or 8mm tranny kit at www.stormerhobies.com or www.hobbyshopnj.com
WY
BTW if you were to go for the new UE tranny kit, you would not have to set up with 1/8th diffs, alls you would have to do is drop a tooth or 3 on the clutch bell to make up for the gear ratio, I run a 13 tooth bell on my truck, so the tranny kit might be perfact for me instead of going to a bigger bell, cause those of us out there running a 1/8th setup on our maxx know how much easier it is to find a 13 or 14 tooth bell instead of a 15-18. ANyways unless I missed something, I dont think you need to mod a tranny case for this new FOC to fit in it, it doesnt look any wider then an 8mm tranny gear.
WY
Originally posted by bubbafien
i think that it is thinner than 8mm. you would not have to but it is recommened because it is designed for the 7.5 diffs.
bubbafien
bubbafien
Alright so if iam understanding this i should go with the new UE tranny kit instead of the 10mm and just get about a 13t clutch bell, can i do that with a stock clutch size (not a 1/8th style clutch) i am using the flywheel and clutch from the older tmaxx (.15 engine).
WY
Actualy if your running the stock bell(20 tooth) a 16,17 or 18 would work very well!! And no a stock bell is not the same pitch as a 1/8th, I would sugjest running a 16-18 tooth bell with your setup.
