Big Bore Shock Oil
Big Bore Shock Oil
I was wondering what oil i should run in my Big Bores with the light Blue trinity springs. I have trinty 35wt oil and trinity 50wt oil. THX
NY
RE: Big Bore Shock Oil
I use 45 wt with those same shocks on my Sportmaxx. I also use those same springs. To me this is a pretty stiff set-up but for the track I race on its fine. If your just bashing around I'd use the 35 wt.
How heavy is your truck? Do you have a lot of aluminum goodies on it? If so, heavier weight oils can be a good thing
I use 30-45wt in one of my stock maxx's and 50-70wt for a HEAVY aluminum ridden T-maxx I run. It seems to work pretty well!
