My Micro MT Truck Project
I saw potentional in one of my little brothers toys the other day. I could drop the motor right into a mini truck and the only thing that would need to be fixed it the clutch...its too loose. I will get some pictures up of the truck but i have some questions to ask. Its a solid axel truck so i will probably be doing 4 link suspension unless there is a better/easier way. Does anyone know where i can find a page that has detailed pics of some? And what is the easiest way to steer the truck. I was thinking of making custom dogbones but i would have to modify the wheels too much to do so. I was thinking of setting it up like the mini t. I plan on using a hs 81 servo for steering and a 1200 mah 2S1P etec lipoly pack for the battery. The motor is a mystery motor so i have no idea what the name is or how many amps it pulls. Does anyone know how i can figure this out? Im thinking a 15A esc should be sufficient...what do you all think? Pics to follow if i can get them uploaded.
