Storm SUT Steering
Storm SUT Steering
I have a Storm SUT and whenever I give it full throttle it randomly pulls hard to either the left or the right - it is not consistent.
I have put in a stronger airtronics steering servo, put oil in the diffs -7 5 1, adjusted, toe in/out , camber, put ball bearings in the steering servo saver, changed tires. I am at a loss as what to try next.
Any thoughts. I have a friend who has also purchased one and his exhibits the same symptons.
YT, BOTSWANA
RE: Storm SUT Steering
What???? If you are pulling to either side on throttle while going straight, you need toe IN. Most likely in the rear.
Matt
Matt
ORIGINAL: BFT
Add some toe out to both front tires.
AL
I'm afraid what's happening is not related to suspension set up at all. The only way we could get the SUT to settle down and pull straight was to run 100K diff oil in the center. Anything lighter than that and all the power wants to unload through the front diff, and as soon as one or the other front tire goes the least bit light, all the power goes to that side. We tried 60K center and that helped keep enough of the unloading down so that the front tires would grow at the same rate, but it still wanted to unload to the front. We are waiting for some 80K oil to see if that works, but until then we are running 7K F,100K C, and 1 or 3K R depending on available traction. If it's slick run 1K in the rear, if it's not run 3K.
YT, BOTSWANA
Thats really strange FHM. I've driven those SUT's, they seem really tight, and track a straight line really well. Are you using the stock motor?
Matt
Matt
AL
ORIGINAL: ThermalRD
Matt
Matt
Oh and to answer your question regards using the stock engine, no, we are running 5 and 7 port Novarossi 21's and a couple of older OS 21's, an RZB and a V01.
OK, I couldn't find 100k so I put 120k in the center.
same problem.
Went from 7k to 15 k in the front.
same problem.
Tried more toe out.
same problem.
Tried more toe in.
same problem.
So, any other thoughts. 2 of these things do the exact same thing and nothing we've tried helps. Is this so called SUT "supertruck" just plain uncontrollable "supersuck"?
same problem.
same problem.
Tried more toe out.
same problem.
Tried more toe in.
same problem.
YT, BOTSWANA
Well, i dont know how familiar you guys are with racing setups, and 8th scale in particular. I can tell you this though, in my experience the trucks that track side to side on the straights under full throttle are usually because they have a spool in the rear, or some other diff locking device. I've driven an SUT, and didnt have the problem you are having. I can try to help you out with setup though. Heres what i would try. I would put a 3k front-15k center-1 or a 3k in the rear. I would have 1 1/2 -2 degrees of toe in up front, and 2-3 degrees of toe in at the rear. Camber, i would put 2 degrees rear, maybe 1 degree up front. On the suspension, i would keep the front a-arms level, while the rear make the bones level. That should leave the rear sagging slightly.
Matt
Matt
ORIGINAL: Maxx-Crusher
same problem.
same problem.
Tried more toe out.
same problem.
Tried more toe in.
same problem.
same problem.
same problem.
Tried more toe out.
same problem.
Tried more toe in.
same problem.
YT, BOTSWANA
Another thing to check is metal binding, or rubbing. This can cause interference. Its really common for a glitch to cause the wheels to point to the right or left when something in the throttle linkage is rubbing. So turn all your radio equipment on, and pull your throttle a couple times while the truck is sitting there. Just to make sure nothing is binding causing a glitch.
Matt
Matt
