RC Monster Trucks Discuss rc monster trucks in this forum
OK need help
Old 04-05-2004, 04:01 PM
Sav21crzy
Default OK need help
I just put in a new steering servo like a week ago and whenever i would steer it would make the wheels turn to the right more and it would barely turn then to the left .
Can some1 please help me ??
Old 04-05-2004, 04:09 PM
Dale Gribble
Dale Gribble's Avatar
Default RE: OK need help
What steering servo are you using?
Is the servo saver in good shape? Is the servo saver spring there and in good shape?
Did you center the servo before you installed the servo saver?
I am guessing you have the Savage (your username) since you didn't say. I think the servo saver used on the Savage is JUNK! I bought a Kimborough Servo Saver and am much happier now- it is worth it, but not necessary if your stock one is in good shape.
Now, if the screw holding the steering linkage to the servo saver is too long, I have seen it scrape the top of the servo and catch the servo.
By hand, does the steering smoothly travel from one side to another (when the servo is off?)
Try some of this stuff, and let us know.
Old 04-06-2004, 03:15 PM
Sav21crzy
Yeah, it turns smootly when i do it by hand and im sure that the screw isn't too long. How would u center a servo ?
Old 04-06-2004, 03:19 PM
Project_2501
pull it out of the truck, activate the servo batteries and radio, turn it a few times and let it center (without saver on) then, when its centered put the saver on also pervectly centered. it wil now be, centered! plop it back in, and you now have a perfectly centered servo! hope this helps.
